Lightweight 26" wheel build?
Hi there folks, I'm looking to build a set of lightweight 26" 10 speed mtb disc wheels for a xc bike which needs a thru axel at the back and a qr at the front (the forks have been replaced). I'm much more at home with road bike parts than mountain bikes, so don't know where to start. Can you recomment some affordable lightweight rims and hubs? Happy to consider new or second hand if that is easier to source for 26". The bike won't see much heavy riding and the rider is light but I want it to be light partly as it has to be carried up 4 flights of stairs! If I could built a set of around 1500g wheels that would be awesome. Thanks in advance Helen
why not 27.5"?
internal width?
bor xmd 333 rim:
https://www.amazon.co.uk/BOR-ULTRALIGHT ... B07B98QMK6
https://www.ebay.com/itm/201903768332
internal width?
bor xmd 333 rim:
Well the rear is currently 27.5 but the replaced front fork is for 26" wheels and I thought it would look smarter if they were both the same!
Not overly bothered about internal width, bike is a few years old so doesn't have the clearance for balloon tyres.
These look really nice and light thanks - always like things with a weight limit as most mainstream gear is over-built for a small rider.
I've found there are less mtb hub options for 28 spokes, would you say that's the case? Any ideas for a good hub (QR and thru axel) that would go with these?
right now choice of 28h hubs is good,
centerlock with convertable caps,ind.bearing:
novatec d791sb-cl/d792sb-cl (ali link or ebay)
a little too loud; with replaceble QR/TA caps; boost/non-boost, 6-bolt/centerlock
centerlock without convertable caps,ind.bearing:
shimano hb-/fh-mt410/mt410-b/mt401
(boost ta/non boost ta/qr, not light)
centerlock without convertable caps,ball bearing:
other shimano hubs
6-bolt,ind.bearing:
novatec d791sb/d792sb (ali link or ebay)
hope pro 4 (more expensive, easier to buy)
circus monkey disc hubs (lighter, ebay only)
other shimano hubs
6-bolt,ind.bearing:
Thank you my mystery friend! Even I have heard of Novatec hubs. As a novice to this mtb business I am amazed and excited to learn that the difference between quick release and thru axel can be nothing more than an end cap.
Further suggestions still welcome...
I can heartily recommend Bikehubstore as an excellent U.S. source for wheelbuilding components. Reliable and responsive CS.
https://www.bikehubstore.com/
Thank you Sanrensho, sadly I am in the UK but have found some good sources here too
