Getting a warranty frame replacement for a 2018 hi mod scalpel with a 2021 hi mod frame.
I've noticed that the frame has now gone to 148x12mm boost.
This means my 2018 142x12mm hollowgram wheel won't fit correctly.
Thoughts on a way to fix this? Doesn't look like adapters are availiable... might have to get a new hub and get the wheel re built?
2021 Scalpel now gone to boost
You should be able to buy a spacer kit and new axles.
Yes there's a spacer kit for the short term. But annoying as the 6mm spacer drops out when you remove the wheel. Having to dish it over further means you lose the benefit of a dishless wheel which is a big benefit to Ai.
I'm inclined to think Cannondale are responsible for giving you a functional bike. I'd be asking if they will supply a rear wheel or rear hub as well.
Thanks mate. I asked the same question yesterday and you are correct... they will supply a fucntional bike with either of the two options you mentioned which is good!grover wrote: ↑Thu Apr 15, 2021 2:36 amYes there's a spacer kit for the short term. But annoying as the 6mm spacer drops out when you remove the wheel. Having to dish it over further means you lose the benefit of a dishless wheel which is a big benefit to Ai.
