Hellow.I have a rockshox reba rl 26 2014 with 100mm travel and remote lockout.The problem is that the travel is fixed and my fork hasnt spacers to chang the travel.
So the first question is what parts i need to make my fork 120mm travel and the second is how i can remove the remote lockout and get a normal cap lever
Στάλθηκε από το SM-J510FN μου χρησιμοποιώντας Tapatalk
Rockshox reba travel increase
Usually to remove the remote lockout you need a new damper (unless you literally just want to remove the lever, but you will lose functionality that way) the travel can be changed with a new air spring rod. You can find the user number needed if you look up the rockshox spare parts catalogue for the correct year.
