New cheap light stem (MT Zoom)
robbosmans
by robbosmans
prebsy wrote:in the vein of alloy super lightweight stems has anyone looked into the newmen evo sl 318.2 ?
It would be a big pain when traveling a lot or removing your bars etc, but yes its looks good
GPetsis
by GPetsis
Klaster_1 wrote:
Thu Jan 14, 2021 11:54 am
GPetsis wrote:
Thu Jan 14, 2021 11:49 am
Why then someone's going to pay 100-150euro for an expensive one stem that eill be lees stronger than a 3d forged light stem?
Because it's lighter or looks cool. Everyone has different priorities.
The machined one looks better.that is true.
But weight?no.they are similar.only carbon ones are lighter.
carbonazza
by carbonazza
prebsy wrote:
Wed Jan 13, 2021 11:34 pm
I have the 90mm on my gravel for 3+ years.
Only drawback is when you put the bike in a travel box. You must remove the stem from the fork, instead of just the handlebar from the stem.
Replacing the stem with 40mm of spacers avoid the headset to move.
Kurt1980
by Kurt1980
carbonazza wrote:
Thu Jan 14, 2021 10:44 pm
Did you manage to get drop bars in that stem? How so??
carbonazza
by carbonazza
Kurt1980 wrote: Did you manage to get drop bars in that stem? How so??
Yes. Like you do for the shifters, from one end to the center.
Kurt1980
by Kurt1980
carbonazza wrote:
Sun Apr 04, 2021 10:07 pm
Thanks!
Do you think the stem would be able to navigate round the tighter radius of compact bars?
Also, do the clamping faces offer enough surface areas to not delaminate carbon bars?
Intriguing possibility if I can overcome the inconvenience of no removable face plate.
Cheers!
carbonazza
by carbonazza
Kurt1980 wrote:
Mon Apr 05, 2021 2:34 am
Cheers!
It has a wider and smoother contact surface than a usual stem, no delamination so far.
I plan to change my gravel bar to a flared, that is quite tight, I'll let you know if I needed another stem.
Kurt1980
by Kurt1980
carbonazza wrote:
Wed Apr 07, 2021 10:26 pm
Cheers!
Thanks for the info, do keep us posted.
Cheers,
Kurt
Roadbiker10
by Roadbiker10
Cheers!
Hey. I'm interested in this stem for my gravel. Do you think it will be able to slide on to a Zipp SL 70 Xplr bar?
Scott Addict RC 20 2021
Ridley Kanzo Adventure 2022
Femboy
by Femboy
imma say that kalloy uno is still better at 20 dollars and I have clapped the *f##k* out of it training and racing it on my main xc build and its fine
Kurt1980
by Kurt1980
Updating. After far too long sitting on the fence... splinters in the backside gave me some motivation.
Purchased the Newmen 2 bolt stem.
I had to push a bit past the recommended opening to get it round my compact bars, so keep that in mind if you purchase these. The journey onto the bars kind of looks one way.... caveat emptor.
That said, they look pretty nice. Certainly more modern than my previous setup. Light obviously, and I assume pretty stiff.
I'll update this thread if I have any problems.
Kurt
