New cheap light stem (MT Zoom)
- robbosmans
- Moderator
- Contact:
New MT Zoom stems
6 deg. weights: 70mm (81g), 80mm (85g), 90mm (88g), 100mm (95g) 110mm (99g)
17 deg. weights 70mm (79g), 80mm (88g), 90mm (91g), 100mm (98g) 110mm (101g)
Can be even lighter if you replace the steel hardware with ti
£35 with VAT
£29 without
£35 with VAT
£29 without
I needed one 60mm 6deg.
Enviado do meu SM-G960F através do Tapatalk
Doesn't it look identical to Lyti?
- robbosmans
- Moderator
- Contact:
Yes it does, looks like they have a lot of products in common. So probably buying from the same supplierKlaster_1 wrote:Doesn't it look identical to Lyti?
Also looks identical to the Wren stems, though Wren seems to be claiming slightly lower weights for a given length...
https://wrensports.com/product/crazy-li ... inum-stem/
To be fair, once your talking about light, cheap forged aluminum stems, a lot of resellers are likely sourcing from the same OEM.
They should flex roughly as much as expensive light aluminum stems, but are maybe more durable
in what way would they be more durable?
on a mountainbike, is it even possible to feel the flex from the stem separately to..tires, fork, all that?
by the way, what really sucks on light cheap stems are the bolts, which are in my experience single-use
The stems above - and most cheap stems - are forged, which will (very generally spoken) result in a stronger part compared to machining, which is how expensive stems are often made.
i am confused..
Cheap al stems stronger than expensive stems that are machining?
Why confused?
Why then someone's going to pay 100-150euro for an expensive one stem that eill be lees stronger than a 3d forged light stem?
Because it's lighter or looks cool. Everyone has different priorities.
