XTR pedals driving me crazy
Have been using (past three years) Lake brand shoes with XTR pedals. The tread/pedal interface squeaks horribly and is driving me insane. I find myself avoiding my MTB because my road setup is so quiet and perfect. I have tried several other brands of shoes and nothing fits very well so I'm kinda stuck with the Lakes. Would a different brand of pedals make a difference? Maybe something with less shoe/pedal contact?
I also had problems with Lake shoes. I could never get cleats to not creak on those.
Are you using Lake for width? Or another fit issue?
I have also has issues in general with Shimano SPD pedals- They always start creaking when there is the slightest wear- it is usually the pedal rubbing againt the shoe rubber. You can't trim the rubber, or it rocks even more. I have tried lubes, waxes, fresh cleats, differnet shoes- It all ultimately creaks.
Recently I switched to HT pedals- These don't creak. The interface is tight, and they have 4 degree and 8 degree cleats. I have put these on all of my bikes- No noise. I am super happy with these.
- robbosmans
- Moderator
- Contact:
You just need to lube the pedal, this is happens to almost al spd pedals, no big deal
Verzonden vanaf mijn iPhone met Tapatalk
Just any bike lube? And all over the clip? Mine are driving me crazy. Thanks!robbosmans wrote: ↑Sun Jul 05, 2020 8:23 amYou just need to lube the pedal, this is happens to almost al spd pedals, no big deal
Unsure what you mean by 'lube the pedal'... can you expound?robbosmans wrote: ↑Sun Jul 05, 2020 8:23 amYou just need to lube the pedal, this is happens to almost al spd pedals, no big deal
@fastezzie, as @boots2000 mentions, I have expereienced the same when the cleats are worn by some amount. New cleats generally take care of the creaking for me. I have extended the life of worn cleats by placing some gorilla/duct tape on the sides of the XTR where the shoes contact. 1 or 2 layers thick, and fully acknowldeging the tape wears off after 4-5 rides.
"If it ain't broken, it could be lighter"
- robbosmans
- Moderator
- Contact:
Just normal grease in the spring mechanism and and a spray lube or chainlube on the cleat interface
Eggbeaters are the worst pedals I have ever put on my bike, the body rusted and the bearings where shot after one mild winter, the cleats are also way to expensive
I was getting this with XTR pedals. Gave the spring a good spray with a dry teflon lube and smeared all over with red grease. Has been silent since. If it starts up again I'm going to give them a full service down to the bearings just to rule that out.
- robbosmans
- Moderator
- Contact:
Try a dry lubeSjoerd wrote:I've lubed mine as well at times, but it just attracts so much dirt. Surely there must be a better solution to cure the squeaking.
