Ultralight Chinese Carbon Seatposts
itapersita
by itapersita
I would like to purchase a selle Italia carbon saddle but I am afraid it's not compatible
Seph
by Seph
hello. is anyone using the eliteone on an mtb?
the brand seems have a good quality but i'm not sure if is suitable for offroad.
rhender
by rhender
Seph wrote:
Wed Sep 13, 2023 9:09 pm
This is anecdotal of course and doesn't mean that all of the seatposts are safe, but I have been using the eliteone on my XC bike all season and haven't had an issue. I weigh almost 90kg and haven't been particularly gentle.
Seph
by Seph
rhender wrote:
Wed Sep 13, 2023 10:39 pm
thanks! do you have this one or the other one with a thinner upper part?
https://ae01.alicdn.com/kf/S1e05f0ce256 ... 213a2b.jpg
Seph
by Seph
Can you share a photo?
Inviato dal mio Redmi Note 9 Pro utilizzando Tapatalk
rhender
by rhender
Seph wrote:
Thu Sep 14, 2023 8:46 pm
I have the one with setback in 30.9 x 400: https://www.aliexpress.us/item/22558000 ... 4itemAdapt
It is light and it hasn't broken, but it is pretty flexy just an fyi
Primera23
by Primera23
Wanted to chip in. I use the elita one post on my hardtail and rigid bike. Both have been flawless since installation (+3 years). I have this version https://www.aliexpress.com/item/3294008 ... 1835419919
Upgraded the bolts for Ti for saving a bit of weight. As stated: cheap, light and durable (I'm around 75kg). They are a bit flexy but for me this isn't a downside. Gives more comfort.
Seph
by Seph
I was looking at this one specific
https://a.aliexpress.com/_EjyBfV9
Seems a bit more robust on the upper part. At least by the look Image
robbosmans
by robbosmans
Primera23 wrote:Wanted to chip in. I use the elita one post on my hardtail and rigid bike. Both have been flawless since installation (+3 years). I have this version https://www.aliexpress.com/item/3294008 ... 1835419919
They already come with ti bolts?
LanceLegstrong
by LanceLegstrong
robbosmans wrote:
Tue Sep 19, 2023 11:01 am
Mine were steel.
Specialized Tarmac SL7
Specialized Crux
Velobuild 168
Trek Checkpoint ALR
kode54
by kode54
Two friends bought an ultra light Aliexpress seatpost for their Pinarellos. It worked for several hundred miles...but needless to say, the saddle started to slip fore to aft a few times even after tightening and using carbon paste, etc. It turned out that the hole where the bolt passes through was wearing out or erroding due to constant forces. There happens to be no metal washer and eventually, the bolt wore through. If anyone gets one, make sure you inspect the bolt and whether or not a metal washer is embedded in the recessed hole or not...otherwise, the bolt will wear out the carbon due to the bolt head diameter which is thinner than a washer.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
Primera23
by Primera23
No, they are delivered with steel bolts but I have amassed quitte an assortiment of Ti and Alu bolts in various shapes, sizes and colours. I kind off switch all bolts immediately when something arrives :D
Seph
by Seph
I was looking at some online reviews. I saw some photos showing the internal diameter, in some photos seems normal but in others seems a bit too thin.
Dunno if I am going to get it anyways or get a light alloy one.
aeroskii
by aeroskii
The elita one seatpost I have is really nice. Decent amount of deflection which is nice on the hardtail.
Would highly recommend
