Dropper or not?
SpeedyChix
by SpeedyChix
For XC riding with infrequent steeps or need to get behind the saddle, is a dropper worth it?
Proficient and quick on twisty stuff and not sure if it'll be a benefit or a distraction.
What's the exerience of riders here and if you're using one, what's been the best for performance and minimal service needs?
adrenaline junkie
mattr
by mattr
I've been experimenting with one that i got on the cheap, TBH, when i switched back to the race bike this spring, i didn't *actually* miss it that much, if at all. I'm going to carry on switching back and forth and see if it does get more use when i get a bit fitter.
Lots of short steep (near vertical) drops round here and lots of fast rolling singletrack, so you'd think they were all but essential.
SpeedyChix
by SpeedyChix
Thanks. I've encounterd a couple of nasty drops this year that might have been a bit safer / tidier getting down with a dropper but so far that's it.
adrenaline junkie
mr2scott
by mr2scott
I've been anti dropper for a while. I've had droppers on multiple bikes, they are always sticking, malfunctioning and loosing me more time than they save me.
I only ever wanted a dropper for huge roll downs and drops.
I just put a Bike Yoke Devine SL on my XC bike and I'm sold on it. It's the only dropper I've used that actually works well, it always goes down and always goes up. It's only 80mm of drop which is more than enough for me and it's lighter than most. HIghly recommended if you want to add a dropper to your light weight XC bike.
sandbox
by sandbox
I just got one for the 1st time. Been pretty anit-dropper for a long time. Old and stubborn I guess... I really like it now. Took a couple rides to "get it", but I use it a ton now. Even in flat, flowly sections, I'll drop it 1/2-1", just to lower the BB a touch and get better traction. Pretty cool tool. Ultimately, Id like to have the wireless one that RockShox/SRAM put out. Just for ease of taking on/off.
Besides- Kate C just won a World Cup on one.
d36
by d36
I'm getting rid of mine for a couple of reasons
Im short and my position is fairly foward so I have no trouble getting behind the seat
Pushing the seat down with your bum takes extra energy
They also seem to break at really annoying times (I had to ride with a seatpost that kept drifting down 3 hours into my last xcm event)
TheRich
by TheRich
d36 wrote:
Tue May 28, 2019 1:37 am
A lot of problems come from installation (like inadvertently activating them because of cable tension) or lack of maintenance (Rockshox hydraulics), but if yours doesn't work, get one that does. I've never had a problem in years of use, most people never have a problem.
When it comes down to it, there's a level of confidence, and therefore speed and safety, without a dropper post, and there's a higher level you can achieve with one when used properly. It's not about simply "getting behind the saddle," it's about lowering your CoG. It's about getting the saddle out of the way and using the best technique possible for the situation, and for technical sections, that technique is NOT standing on your toes with straight legs.
prebsy
by prebsy
If you have extended runs of downhill I find it pretty useful, like over a minute. I have found they aren't as useful if your drop is in the middle of pedalling sections and you are wasting more time preempting the drop and then re engaging after. You spend more mental energy using the dropper than if you just focused on huckin that shiz.
TheRich
by TheRich
prebsy wrote:
Mon Jun 03, 2019 1:44 pm
Practice and familiarity makes that a non-issue in most cases.
Dropper posts aren't an instant power-up, you have to learn the habit of using them to the point where it doesn't require mental energy.
