65mm stem?
maddog 2
by maddog 2
As luck would have it, 60 is a tad too short and 70 is a tad too long,,,,
So far I've spotted in 65mm:
- Raceface Atlas
- Spank Oozy
- Joystick Builder
- Sunline Vone
- Box Cusp
- older Easton Havoc
- XLC all mtn
all of which are fairly lardy at 170g ish, and I'm not too keen on the looks of the last few.
- and the only lightish one Ive found so far is a Pro Tharsis Trail at around 130g
Anyone seen any other 65mm stems? Almost every stem is a mutiple of 10mm.
[31.8mm, rise not an issue]
scant
by scant
i think straitline used to do a 65mm stem. again not particularly light...
ta
scant
silvalis
by silvalis
deity copperhead.
possibly heavy and chunky.
Chasse patate
Marin
by Marin
Or go and measure actual stems, I'm sure you'll find one labeled as 60 or 70 that actually comes out as 65.
krzysiekmz
by krzysiekmz
Uno 60mm is actually right about 65mm
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
F45
by F45
I cannot believe that 5mm is so important to you.
maddog 2
by maddog 2
I know... :shock:
I've been trying to tell myself 70mm is okay but I'm dead sensitive to bar position, with my creaking skeleton.
On the full susser it's less important but this is a rigid 29er so everything needs to be exactly right.
Marin
by Marin
You can adjust by 5mm by rotating your bars
mattr
by mattr
You can adjust by 5mm just by ignoring it ;)
Christ, most peoples height varies by twice that during the course of the day........ mostly in the spine.
You probably need two stems, 70 before about 3pm and 60 after, for the afternoon commute and night rides ;)
maddog 2
by maddog 2
I like the sound of that. I could swap the stem at work to a 60mm, then swap it back for a 70mm when I get home. Bingo. Cheers fellas.
jemima
by jemima
Kalloy ASM03 in 65mm. Zero degree. 135gm?
Klaster_1
by Klaster_1
My 60mm Kalloy Uno is actually 65mm center to center, 79g with Ti bolts.
ooo
by ooo
$24.8 FOURIERS 65 mm stem 145 g
I think Fouriers is OEM partner for PRO shimano stems and some other PRO parts
Zakalwe
by Zakalwe
Good effort with the labels
maddog 2
by maddog 2
cheers all. The Pro Tharsis is fitted and working well.
It has an internal collar to preload the headset, rather than need the topcap+bung to do this job. So I've removed the 60g-odd steerer bung and replaced it with a lighter nylon bung that's only job is to hold the topcap in place. So I've saved some weight there.
