newer style crank for 73mm BSA frame
YourConfused
by YourConfused
I have a 73mm BSA threaded bottom bracket shell frame and I am trying to figure out what type of new crank/BB setup fits this. I am thinking that the that the 386 evo type may fit but I am not really sure and don't know where to start looking as I haven't upgraded in years. I have some nice, forget the brand, vintage-ish BB, square taper, that has less than stellar bearings in it now. Weight of crank arms, spider, bolts and BB is 600g currently, so I am looking to lighten it up a bit. I ride mainly singletrack so I don't need bomb proof stuff. Any info or thoughts would be appreciated. :D
bm0p700f
by bm0p700f
That's a fairly light chainset. XT with BB is not much lighter.
YourConfused
by YourConfused
bm0p700f wrote:
Sun Oct 07, 2018 10:58 am
Thanks for the input.
Probably a waste of money then to bother with an upgrade. Is there a good source of "good" bearings anywhere? I replaced the bearings in fy fisher, press fit 1990's, about 20 yrs ago and they are still amazing bearings. The shop I got them from closed so I am not sure where they came from.
mattr
by mattr
Any bearing from a decent manufacturer will be fine, I tend to use SKF, as they are local to me.
Get a 2RS type for better sealing.
