Recon 10sp (shimano) Titanium cassete+shifter.
michealxgrzz
by michealxgrzz
I've just bought Recon 10sp (shimano) Titanium cassete+shifter which used for 9sp rear derrailleur.
After install it, I discover problem which when I shift using their shifter, the third click from the small cog always skip 1 cog. other than third click problem they are flawless.
My setup
Shifter: Recon CR-10sp
Cassette: Recon Titanium 10sp 11-36
RD: XTR M970 9sp (non dyna sis)
Any body hv use recon cassete+shifter? Any good?
scant
by scant
I cant comment on recon. but M970 9 speed certainly doesnt work with xtr 10 speed. so maybe its a cable ratio pull issue?
ta
scant
bm0p700f
by bm0p700f
Yes it is. Cable pull incompatibility.
alibudia1712
by alibudia1712
you should use shimano road 10 speed shifter for flat handlebar.
Sent from my Redmi Note 5 using Tapatalk
mike
Resident Pro
by mike
you need 10 speed shifter or go to friction.
