29 wheels on Fatbike
boubou76
by boubou76
Hi guys,
A little trick I made to adapt some 29inch wheels on a fat frame for a trip.
A got normal 15mm and 100 mm long front hub and machined a custom front axle to adapt the 135mm spacing fork.
The frame rear triangle is assymetric with normal 135mm spacing hub. I relace a bontrager wheel with offset spoke holes to match the offset of the hub and limit the difference of tension between the two sides.
