Chain wear on XC bike
kavitator
by kavitator
Hi!
What do you think about replacing chain (SRAM) almost every month - i am 82-85kg and sometimes almost every ride is st hill (1200-1600elevation)
Steepest climb has 27% - avg is around 15%
Which chain has longest life?
caad4rep
by caad4rep
How many miles a month do you ride and what are the conditions like?
A month seems overkill to me but maybe you are throwing down epic mud miles...
TonyM
by TonyM
+1
Yepp the chain wear depends also on the kilometers/miles, the weather condition, etc...
kavitator
by kavitator
one ride is around 50km- but climb is very badass in the hardest part.
I also shift a lot to get in high cadence.
Probablby combination of fine sand (dust) and high torique (steep long climb and low gear)
Also i didnt clean chain after every ride (who has time for that :)
Thats why a ride up there :beerchug:
02GF74
by 02GF74
Are you saying you think you need to replace the chain or need to
Do you have a chain wear gauge, that will answer your question.
kavitator
by kavitator
I replace it - meseaure it with caliper 132.6mm - if it is more it must be replaced (also it is louder and shifts bad)
It was last year - arpund 5-7 climbs (5 with 1500m ascent and one with 2000m) and chain was "streched". Also that time i was in good form (national tt champ in cat)
This year i get new bike and soon will be in betterform (6months recovery after broken leg) - so i question before it happenes :D This chain also has 132.6mm (around 700km and 13000m ascent)
I use method 132.6mm for road bike too and it works. After 132.7mm shifting is worse)
bm0p700f
by bm0p700f
Thats a campagnolo recommendation i think and applies to there chains with very little play from new.
Calnago
by Calnago
Yes, that’s the Campagnolo guideline, and I use it too. It’s a pretty conservative guideline but it is in fact a good one. Over time, when I’ve noticed a degradation in performance, I’ve measured the distance and confirmed that the 132.60mm guideline seems to be a very good point at which to replace chains if you want everything to work as intended. It’s a little shy of the 0.50 mark on say, the Park gauges, so for practicality and ease of use the park 0.50 mark is a good approximation of the “practical” point at which I will change a change.
I use Campy and don’t rotate chains as I use the peened pin, but I wouldn’t rotate chains anyway. The only time I change chains before they are worn out is if I’m changing chainring sizes and it needs a different length.
I have a bunch of wheels with a bunch of different cassettes, making it difficult to really track how many miles each combination has on them. But if I didn’t change anything and used the same drivetrain all the time, I’ve found that I can get two chains per cassette. Install a new third one and it will be likely be skipping from day one.
The other thing that really affects chain/cassette life is rider weight, and power of course. And, in the case of the OP, a bunch of grinding grit and steep uphills doesn’t help things either.
02GF74
by 02GF74
I don't know how you can accurately measure it with vernier calliper, how do you ensure you have the centre of the pins?
Spend 5 bucks on a gauge, trust me, I used to use callipers too but gauge is much simpler, accurate and consistent.
ooo
by ooo
May be you forget to change front chainrings?
bm0p700f
by bm0p700f
Look at campag instructions to put the Vernier in the rollers.
MikeD
by MikeD
Use a ruler or tape measure on the bottom run of the chain. If it measures 12 1/16 or greater when lined up over the rivet centers at 0 and 12", it's worn out.
boots2000
by boots2000
I think you are smart. XX1 and Eagle cassettes are expensive. Chains are cheap.
