XTR 12 Speed
wingguy
by wingguy
madik wrote:
Fri May 25, 2018 7:00 pm
TurboKoo wrote:
Fri May 25, 2018 5:32 pm
2x12 also available with 28/38 from chain rings and 10-45 cassette.
According to bikerumor's article, the 2x is only available with the smaller range 11s cassette 10-45. So no 2x12.
You have misunderstood. There are 2 10-45 cassettes, a lightweight 11s and a tighter ratio 12s. As the lightweight option the 11s cassette is intended for 1x use. You can have 2x12 10-45.
commendatore
by commendatore
I’m hoping there has been actual advancement in the mud shedding of the new pedals. Maybe these match the “prototypes” we have seen under pro CX racers?
bm0p700f
by bm0p700f
My old xtr m985 groupset is looking a little out dated now.
I am sure every hub manufacturer will offer a freehub before the end of the year.
I wonder if that freehub will make it over to Dura ace 9200 12 speed.
ooo
by ooo
microspline is dt/shimano only
TonyM
by TonyM
When is the Di2 version scheduled?
Marin
by Marin
bm0p700f wrote:
Tue May 29, 2018 11:10 pm
No, only Shimano and DT it seems, it's not an open standard this time :(
InDustWeTrust
by InDustWeTrust
As I have understood it, please correct me if I am wrong, the micro spline thing is not propietary, it's open and anyone can use it. Now, the silence freewheel system from shimano, and the dt swiss, or king or... is propietary.
Let me know if this is correct. I do not see the chinese not selling hubsets for this cassette, one way or another.
InDustWeTrust
by InDustWeTrust
I´m on a 970 XTR with grip shift from sram and 26". No more grip shift + shimano... :cry: :cry: :cry:
maxxevv
by maxxevv
The silent freehub is a patented design, that will be a Shimano exclusive.
The spline is an open standard.
It was developed with colaboration / feedback from DT, hence DT has the headstart on all other manufacturers and it is directly compatible with their own freehub clutch mechanism as it is. Other manufacturers will get around to fitting the design to their hubs as soon as they think its viable a market or figure out how to fit their own clutch systems inside that is.
eliflap-scalpel
by eliflap-scalpel
TonyM wrote:
Wed May 30, 2018 2:34 pm
and what about an update of 11 speeds Di2 firmware to run 12 speeds ?
http://eliflap.it/
F45
by F45
Looks like XTR 9100 11 speed with a X01 Crank is the lightest config.
ooo
by ooo
@TonyM @eliflap-scalpel
Nehcuk @ mtb-news 2018-12-01 wrote: According to a shimano rep, the new xtr di2 will not be in the pipeline until 2021, ie release end 2020.
2018-12-10 catalog weight info update for non-xtr microspline shimano hubs:
FH-MT900-B =263 g
FH-MT900-BS =235 g
old info: FH-M9110 =231g, FH-M9110-B =231g, FH-M9110-BS =235g
F45
by F45
I knew it, the MT900 is XTR quality with just a lower grade finish. Although I wonder why the j bend is 30g heavier.
by Nefarious86
Why do people keep living in this delusional idea that any company would do this.
Using Tapatalk
