quickrelease wheels in thru-axel fork?
Zak
by Zak
Hi
Is it possible and without serious downsides to mount 9mm quickrelease wheels to a fork intended for 15*110 thru-axel?
joejack951
by joejack951
How would you even begin to attempt to do this? I think you'll quickly realize how terrible of an idea it is, unless you are neglecting to mention that the hubs can be converted to 15mm thru axle.
mattr
by mattr
Zak wrote:
Tue Apr 10, 2018 7:22 pm
Hi
No.
The forks are dependant on having the through axle present (it's a structural part of the fork).
jeanjacques
by jeanjacques
mattr
by mattr
Thats the other way round......
jeanjacques
by jeanjacques
The way Zak want.
Edit: my mistake, you are right.
mattr
by mattr
No it's not
Klaster_1
by Klaster_1
I'd say it depends on the hub and design/machining resources available to you. In best case there might be a conversion kit available, but Boost? Probably not. If the hub shell can accept a 15mm thru axle and thinner bearings, you can manufacture custom endcaps and use a Boost rotor shim. I've converted my 9mm QR only Novatec D711-SB to 12mm thru axle by drilling out the hub axle and making custom endcaps.
LeDuke
by LeDuke
If you have a hub with replaceable end caps, yes, you could do this.
Example:
My DT Swiss 240 hubs can be 5mm QR, 9mm thru bolt or 15x100mm thru axle, and with an aftermarket end cap, can be 15x110mm (Boost).
Zak
by Zak
Thankyou for all the helpful answers!!! I hoped there was an easy solution, but I can see there is not. And since the wheels are nothing special I will not go down the complicated road....
:beerchug:
