Record breaking!7.19kg 29er full suspension bike
MichaelB
by MichaelB
SRICarbonWorks wrote:
Wed Mar 28, 2018 12:31 pm
.......Rotor: Alpha (38gX2)
Has it actual;ly been rideen with these ?
Reports that I have seen in a few places seem to indicate that these don't really function well as brakes ... :shock:
roseyscot
by roseyscot
I stared a little too long at the pictures and I could hear the carbon cracking over the internet!
02GF74
by 02GF74
02GF74 wrote:
Mon Apr 02, 2018 1:38 am
The later si scalpel frames are lighter still, nevertheless that is quite an achievement, from memory mine after some tweaking is in region of 10.5 kg.
Now down to 10.36 kg after changing xt brakes to xtr and xtr shifter/mech. Brakes changed primarily due to amount of lever travel on xt, xtr better but still not as good as sram level, I do like my brakes to be set up with little travel prior to engaging.
alber84
by alber84
beautiful, but obviously for a cyclist of no more than 70kgs ....
sqber
by sqber
Too deep pockets plus too much time equals a bike that is practically unrideable (if only because it is so expensive to brake something ... like the rider when some flimsy part cracks). You can shave some grams by draining rhe oil from your brakes - visually it wouldn't change anything.
TheRich
by TheRich
I'm sure it would be a great gravel bike
Moyo
by Moyo
a great project and bike. A compliment to this point. I myself am weightweenie and share the lightweight passion. Have a custom scott scale hardtail 29" with 5.9kg and also drive the clavicula dp with octa one chainring or the maxxlites with tubolito.
Only I think, as uncompromising as you were in the selection of the components to get every gram, so compromising you will have to use the bike.
A fully must be able to tolerate a few terrains can at least sniff a mountain and tolerate a little rough. I am afraid that you have built a gravel bike with suspension.
the choice of components and the stiffness make it rather difficult to use on trails, at least you will not have fun there, in my opinion. You can not drive more than asphalt with the maxxlites. got mounted with thunder burts and on the first easy downhill ride on gravel I got scared. the tires (and the thunder burts have more profile like the maxxis) have hardly any grip, the bike is going downhill on loose ground or gravel unpredictable and difficult to act in case of sudden braking, especially by the forward facing seat position.
in short, find your project very cool, but the danger resonates very much, more than with a conventional mtb. Here are two pictures of my hardtail, 5,950g with the maxxlites and 6,170g with the burts. Oh yes, both the maxxlite and the thunderburt I crashed on the first departure on gravel. Both of them ripped the carcass. So I switched to conti race king
cmunozh
by cmunozh
Moyo wrote:
Fri Jul 26, 2019 11:13 pm
+1
I was driving this summer a super light Cube hardtail in Croatia, uphill was a rocket (I got some KOMs even) but in downhill I had to go with pretty carefull as it hasn't grip enought to take the curves porpertly.
My garage: Caad12, BRT C0, Cannondale Scalpel SE II, Specialized Epic pro '92, Swiss military bike '45, Orbea Gredos '87, Specialized Langster '12...
F45
by F45
Agree that with those tires it's just not a mountain bike. What does it weigh with Rocket Rons? Also with the real cassette.
BmanX
by BmanX
I disagree with the comments on the tires. I have been able to ride these tires and live on the wetcoast of Canada. Is there better tires out there by all means yes but it really depends on where you are riding and what you are riding. If you are building the lightest bike, then they are the go to tires and if the rider can ride them, they are fine. This is WW people.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
