Record breaking!7.19kg 29er full suspension bike
SRICarbonWorks
by SRICarbonWorks
My friend's Cannondale Scalpel 29 (size L). Probably the world 's lightest.Have to admit, that is weird.
The construction has not completed yet, his goal is to reach under 6.5kg. The wheelset is overweight. Trickstuff piccola brake, Grigio Carbonio wheelset with Berd Spokes are on there way.
SRICarbonWorks
by SRICarbonWorks
This wasn't a light frame but the owner conducted some modifications.
A DT Swiss X313 carbon shox, reduced 79g
A carbon link rod, maybe some kind of prototype from a bike show, reduced 78g.
Scraped off the paint, removed some metal parts in the frame, and finally polished it with wax, incredibly reduced 170g
Titanium bolts of course.
Final weight: 1730g. Only 90g heavier than UNNO
Klaster_1
by Klaster_1
What rotors are those? These don't look like SiCCC. Also, Gullholm's Spark without pedals should be the same weight wise. Still, this is quite awesome.
SRICarbonWorks
by SRICarbonWorks
Fork: Lefty PBR, 100mm travel, with some carbon parts from Leonardi&Hopp
Carbon&alloy steerer-tube made by Experimental Prototype, only 78.3g
SRICarbonWorks
by SRICarbonWorks
Trigger shifter&rear derailleur: Acros Age 11s with self-made ceramic pulley wheels and aluminum bolts (271g)
Crankset: THM Clavicula dp with Extralite octone chainring (373g)
Cassette: sram XG1195 (262g)
Chain: PYC SP1101 (216g)
Brake: Currently Formula R1 Racing(362g), will soon replaced with Trickstuff Piccola
Rotor: Alpha (38gX2)
tonytourist
by tonytourist
Awesome weight, please post more build pictures!
SRICarbonWorks
by SRICarbonWorks
Handlebar: Darimo 700mm (84g)
Stem: Extralite Ultrastem (74g)
Seatpost: Darimo 31.6X290mm (78g)
Seat Clamp: Carbonice EVA (4.5g)
Saddle: Gelu K1 (47g)
Tyre: Maxxis Maxxlite 29 (336+338g)
Tube: Tubolito S-Tubo MTB (47+45g)
Pedals: Aerolite CLA (59g)
Due to the size of frame, we chose a shorter seatpost. Theoretically Gelu K3 is the lightest saddle in market, but it is not recommended for MTB.
Last edited by SRICarbonWorks on Thu Mar 29, 2018 3:10 pm, edited 1 time in total.
tskubi
by tskubi
Gelu K1 is the mtb sister of Gelu K3 which has holes in it
K3 is for road use only.
http://www.gelucarboncreation.com/
Enjoy your time under the sun.. and when its cold and dark don't worry too much, the world will keep spinning and your time in the sun will come again.
SRICarbonWorks
by SRICarbonWorks
tskubi wrote:
Thu Mar 29, 2018 11:37 am
That was my mistake...
Pat2A
by Pat2A
They updated their Website because before K3 was usable for MTB.
Jepas
by Jepas
SRICarbonWorks wrote:
Wed Mar 28, 2018 6:58 am
Cannondale sells a carbon link ref number KP207/CRB for the Scalpel 29er frame, this carbon version weights about 105g shaving 85g from the stock alloy version.
SRICarbonWorks
by SRICarbonWorks
Weight updating
7.16kg,with Leonardi 9-36T 11 speed cassette, saved 32g (Though sacrificed some performance)
02GF74
by 02GF74
The later si scalpel frames are lighter still, nevertheless that is quite an achievement, from memory mine after some tweaking is in region of 10.5 kg.
Lelandjt
by Lelandjt
I'm curious if this bike got used for a full season and if the parts were kept the same. The build seems more appropriate for a hardtail that is ridden gently on smooth trails so why bother with FS and its weight? Did the bike end up working well on terrain that dictates suspension?
When I started a similar project I quickly decided to take some big weight hits so that the overall package was fun and fast going up or down on the roughest terrain. My Spark RC size XL with 5" dropper post weighs 9.04 - 9.27kg depending on tires.
bm0p700f
by bm0p700f
Very nice.
