Budget Hardtail XC Build USD$1000 - 100% COMPLETED
Erwandy
by Erwandy
ooo wrote:
Mon Jan 15, 2018 2:43 am
Safer approach is to build heavy bike and work with parts 1 by 1 with test riding between changes - but this is very slow
Your approach is reverse, much faster, probably make sense to wear extra protection for testing period.
If we forget about safety, other downside is that some problems can have a consequences (other problems) and it may be hard to figure out what happened first
I have some concerns was about shifting quality - ultegra shifts slow on mtb cassette, i would not go more than 11-32
and while your bike have testing period, may be you don't need high top speed? you can use 32x11-32 or lower combo
about modification - I am worried about stem. it may be ok for road use with suspension for, but not for offroad use,
in some places suspension fork and air in wheel will be not enough to save it from failing...
Yes you are right on the shifting speed. I did noticed that on that mega range ratio the shifting was not as fast as how it should be. This actually sparked a thought on me to switch to 2X11 11-30 setup instead. I race marathon XC mostly and having 2X11 may work better for me.
As for the gearing ratio, I did the maths based on Sheldon Brown calculator and based on repeated tests on several chainring size and cogs, combined with the factor of crankarm length that I use, here's how it looked like:
* at the top end, with 165mm cranks I have found that I can pedal to racing speed with 32t chainring and 11t cogs. If Strava were to be trusted my personal record was a sustained 35kph average speed over 46kmh of non stop endurance ride on tarmac with MTB - and that done within 1.30 hour. I have developed my riding style to spin more and grind less - so I will suck big time at sprints but the type of races I participated does not depend on bursts of speed. What worries me the most is my climbing ratio. At full strength I can still pedal uphill on steep terrain with 1.6 or even 1.7 ratio. But on long and tiring race, having a 1.5, 1.4 or even 1.3 will help a lot to minimize fatigue
ooo
by ooo
with wider 11-32 you can use front derailleur less time - this is real benefit for mtb (and whole reason why 1x is popular)
bm0p700f
by bm0p700f
oops WWism goes bad. Bad luck, good luck it was not serious. So you are just going to have to live with a heavier bike or a maybe a Shimano XT 11-50T cassette. A smaller cassette will be kinder to the RD anyway.
Erwandy
by Erwandy
bm0p700f wrote:
Wed Jan 17, 2018 7:54 pm
Well shit happens :mrgreen:
Yes I have reassessed things up and I will sacrifice adding another 300-400g to attain reliability and comfort with a 2X11 setup instead. Having verly light bike is nice but I need enduring reliability as well. Need to makes sure that I am pedaling to the finish line instead of psuhing my bike hahaha
ooo
by ooo
gear calc link - 36-22x11-32 vs 32x11-50 - (on 26"x2.25") single range is 7.2 to 33 km/h, double range is 7.8 to 37 km/h (or same 33 km/h for 32-22x11-32)
andrew9
by andrew9
Thanks for sharing this awesome build, really enjoying it.
I'm surprised the cassette failed, it must be thinner than it appears in the photos. When you compare it to those SRAM cassettes that are very minimal, but still designed for abuse by heavy riders, I would have thought you would have been fine with your modifications.
I expected the brake lever clamps to fail first, but I do hope that doesn't happen. That hole cut in the stem is also a worry.
I was amused by the person that criticized you for modifying any parts, they must find it annoying having to always pay manufactures a premium to make light parts for them
Erwandy
by Erwandy
andrew9 wrote:
Thu Jan 18, 2018 6:55 am
Well truth be told, I was nervous with the cassette. In person you would see how thin they are. That will be the last of anything resembling that mod that I will do. The biggest mistake was fooling with the rivets - changing them to aluminum was BAD idea lol.
The brake levers are holding good for now.
Erwandy
by Erwandy
ooo wrote:
Thu Jan 18, 2018 12:59 am
Thanks man. Appreciate the calc.
DurianGrey
by DurianGrey
While I personally wouldn't have the confidence to ride that thing anywhere near as hard as I'd need to to win a race, kudos for reporting the failure and good luck with it.
Does the radiator repairman's time or any of the tools used (I'm guessing you do your own painting) factor in to the cost?
Erwandy
by Erwandy
DurianGrey wrote:
Thu Jan 18, 2018 4:54 pm
Thanks.
I already own the tools since I am a gadget addict as well. The cost for aluminum weld is around $18 is so far
dgasmd
by dgasmd
This is one of the most "baller" threads in a while in this site. You hardly see true weight weenie spirit here anymore. Kudos.
hjb1000
by hjb1000
Yes this is a great thread and enjoy the old school WW spirit! Keep it up
mrirocz
by mrirocz
wow...this has to be one of the best threads I have read in a while! You are awesome SIR!
Bhaalgorn
by Bhaalgorn
3-bolt rotor mount on the hub? Crikey...
I admire your passion for this project, but as others have said, I think you've crossed the line into recklessness.
Fastskiguy
by Fastskiguy
What a great thread, you are certainly pushing the limits. Half of me wants to see what you'll do next, half of me wants to demand you replace your hubs and stem right away before something bad happens! Thanks for posting all of this, it's really interesting!
