cheap and light carbon seatpost review
02GF74
by 02GF74
yes, another Chinese cheap carbon fibre seatpost; 31.6 x 400 mm. 0 deg offset - actual weight 200g ( claimed 184g)
UD Matte finish.
See ebay - search T700 Full Carbon Seatpost e.g. item 263259315861
pros:
+ looks reasonable well made
+ does not slip when seatpost clamp is done up
+ light (could be lighter by using Ti bots (M5 45mm and 50 mm)
+ no noticeable flex
+ very cheap!! approx. £ 22.
cons
- photos shows with no logo but item supplied had light grey logos - but could have been be more garish
- saddle slipped back a couple of mm on two occasions so may need looking at torqueing the bolts further
- the lower clamp does not fit perfectly in the post - there is a tiny gap that is taken up when the bolts are done up.
reliability unknown as only had one 10 mile ride.
niklasp
by niklasp
Sounds just like something I would never buy...
akagi82
by akagi82
I will look into that one... Are the rail cradles/cup near the top of the tube carbon?
I was eyeing this one: almost all carbon, with TI hardware.
https://www.ebay.com/itm/Hylix-Carbon-S ... SwIIxZjH9L
02GF74
by 02GF74
No, the cradle is aluminium alloy.
I saw the Hylix post you mention but I have one with similar clamping style which creaks no matter what I do, not saying that the Hylix will do the same but it was one reason, as well as cost, that I did not buy it.
02GF74
by 02GF74
02GF74
by 02GF74
189 g with Ti bolts (M5 x 50 and M5 x 45).
