9 speed trigger shifting
WinterRider
by WinterRider
Methinks I am going to fire my Shimano triggers.
Guess Sram is the option/s? I even might further regress into the .. dare I admit this.. the world of *8 speed rears.
Light/est.. very reliable.. best functioning. Your past experience/s would be most helpful.
Thanks.
*Just something in the water I consume I guess. Fitness rider I am... running 3 rings in front.. chain life of 8's is excellent... double 9's. Just sometimes forget to gauge the 9's... for wear.
Litespeed Appalachian 61 cm
Litespeed Blue Ridge 61cm
Miyata 210 25"
MikeD
by MikeD
I had Shimano 8 speed. 9 is better because of the trigger and thumb action plus wider gear range. Shimano is also better than SRAM. Had those too.
WinterRider
by WinterRider
MikeD wrote:I had Shimano 8 speed. 9 is better because of the trigger and thumb action plus wider gear range. Shimano is also better than SRAM. Had those too.
Thanks Mike.
I'll suggest an 8 speed is as good as.. better than a 9. Why? Chain life.. around 60-100% better. So.. you make the choice of what gear to drop... the 13-26 8 gets most everything done if one carries al rings in triplet... the 26-30 small one a bailout gear... hence no need to carry on in the rear cogs.
Shimano triggers function quite differently.. and that does depend on how their set up.. wire tension and the choice of rear de. But frankly I am all that happy with any of them. I road tested a mid range Scram recently and thought is was very decent. Distinct feel when the gear is engaged downshifting rather than the blow by one can get w some Shimano systems.
I have not used the high end (?) SLX system.. was following a few slimbay auctions recently and they went for 140's. Ball bearings... shorter throw I think.. would like to get some input on those.
But I'm in the world of flat bar bikes ... I like to see the world sans cranking my neck or riding on my scrotum.
Miyata 210 25"
TheRookie
by TheRookie
Apart from the appalling writing which makes knowing what you are saying kind of hard, your views are a bit messed up.
I ran 9 speed for ages, never had any issue with it, super reliable, chain life is fine and certainly nothing like as short as half of a 7/8 speed.
All your issues seem to suggest poor set-up and maintenance to be honest.
WinterRider
by WinterRider
TheRookie wrote:Apart from the appalling writing which makes knowing what you are saying kind of hard, your views are a bit messed up.
LOL.. made my day. I doubt you run any real mileage.... and yes some make a life out of chain maintenance.. I do not. Scrub off your keyboard and then run the brush tween your ears.. lots of space there.
Miyata 210 25"
TheRookie
by TheRookie
WinterRider wrote:I'll suggest an 8 speed is as good as..better than a 9
As good as what?
WinterRider wrote: carries al rings in triplet
What's an al ring?
WinterRider wrote:Shimano triggers function quite differently.. and that does depend on how their set up
No, they always work the same!
WinterRider wrote: mid range Scram recently
A what?
WinterRider wrote:Distinct feel when the gear is engaged downshifting rather than the blow by one can get w some Shimano systems.
Blow by? w?? Can honestly say a SRAM (or even a scram I guess) feels little different when downshifting to Shimano.
WinterRider wrote:I have not used the high end (?) SLX system
XTR is high end, SLX is decidedly mid-range, your knowledge is a long way off which brings other implications for your advice really.
As for what's between the ears, please see notes above.
I do over 2k miles a year, more than enough to judge chain life thanks.
WinterRider
by WinterRider
I hit the snooze button .. time for a nap .. better use of the time. :roll:
Miyata 210 25"
TheRookie
by TheRookie
Yeah, better than learning something eh?
