KP 209 cannondale scalpel bearing kit
02GF74
by 02GF74
Ok, a long shot but anyone know size of bearings (id, od, width) comprising the kp 209 kit for carbon frame cannondale scalpel 29?
There are 6 of them in two different sizes.
ChrizZZz
by ChrizZZz
Yep, no Problem.
I would prefer SKF or other high quality bearings instead of the expensive set of chinese bearings.
29er Carbon:
2x SKF 61800 2RS
4x SKF 61802 2RS
02GF74
by 02GF74
Awesome, thanks a lot; got a set of stainless steel bearings on order so hopefully will this done this weekend.
Have you done this yourself, if so, any tips?
ChrizZZz
by ChrizZZz
Yeah ive done it several times. You should use KP169 or similar tools.
And follow the instructions for mounting and dismounting everything.
02GF74
by 02GF74
Using 4 mm and 5mm allen keys so far have done the 4 upper bearings. Tap them out then press in using a suitably sized socket.
The bottom bearings are the ones with the most play and have come to a temporary stop as I could not get the hollowgram crank off. Either will need to buy the removal tool or as has been suggested, use a rod against the bolt on the other crank.
