Help me lose weight
d36
by d36
My 29er hardtail is currently approx 9.8kg
In a few months time I have long race with some pretty hefty climbs
I think I have reached the point where weight savings start to cost $$$$
Anyone got any pointers for reasonable priced weight savings?
Klaster1
by Klaster1
Main questions is your budget, since weight can be dropped from almost all items. Some things I'd consider first, because these are relatively cheap or save over 100g:
1. You seem to use very heavy stock expander plug, possibly about 50g. A regular star nut weights about 5g. Other options are knockoff Ultrastars by J&L.
2. For under 1000USD you can easily build a ~1300g wheelset.
3. X0 crankset weights about 460g. Maybe look for a used one? It will also require a direct mount chainring.
4. Ti pedals. For example, Xpedo M-Force 8 Ti are about 218g.
Lelandjt
by Lelandjt
I was also gonna say a used carbon crank and Xpedo M8-Ti pedals. You can get a chinese carbon wheelset around 1400g for sub $600. Those 3 parts will get you under 20lbs and at that point you have a really light bike that's not gonna give up anything to your competition on climbs. At that point choosing the fastest rolling tire that has appropriate durability and grip for the course becomes the main concern.
d36
by d36
Lelandjt wrote:I was also gonna say a used carbon crank and Xpedo M8-Ti pedals. You can get a chinese carbon wheelset around 1400g for sub $600. Those 3 parts will get you under 20lbs and at that point you have a really light bike that's not gonna give up anything to your competition on climbs. At that point choosing the fastest rolling tire that has appropriate durability and grip for the course becomes the main concern.
For 1400g I would probably have to build up my own wheels?
I have had a look at the wheels with novatech hubs and I think they come in around 1600-1700.
Carbon rims would probably be a nice performance upgrade.
I'm onto getting a new headset now.
Nice and cheap upgrade per grams.
I've been keeping an eye out for cheap pedals too :D
Budget wise I dont really want to spend more than $500 (I could sell existing wheels to cover a new set)
Lelandjt
by Lelandjt
Hmm, at a $500 budget wheels might be out of reach. You won't get much for your used pair. To get a light set from Nextie, LB, etc you have to upgrade to the hubs above Novatec. They usually have some no name Asian hub that's nearly as light as DT 240s. Here's a more affordable option: Look for the weight of your hubs. If they're decent consider buying some Light-Bicycle, Nextie, or Farsports rims and lacing them to your hubs. You may even get lucky and be able to re-use your current spokes (if they're double butted). The value here is only if you can build wheels or have a friend to do it for free. I think wheel builders charge like $150-200 per pair which on top of the $350 rims would blow your budget.
Used carbon crank, Ti pedals, and two different sets of tires are sounding pretty good.
d36
by d36
I think the hubs are on par with DT Swiss 350
Cant find the exact weight on the 2016 wheels but the 2017 version is slightly lighter and i doubt much changed
bikewithnoname
by bikewithnoname
You can also get thru axles for under half your current weights quite reasonably from Someone like Mt Zoom, or even lighter from Extralite
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
Klaster1
by Klaster1
Some more stuff. Thru axle, as noted by bikewithnoname, are among cheapest options. d36, I think you can also cut the seatpost for 10-20g saving, it looks like 30cm out of 35-40cm out of frame.
Code: Select all
Model                            saving  price     eur/g
EXTRALITE Black Lock Fox         55g     79EUR     1.43
EXTRALITE Black Lock e-thru      51.5g   79EUR     1.53
MT ZOOM Ultralight FOX axle      44g     38EUR     0.86
MT ZOOM Ultralight e-thru axle   41g     42EUR     1.02
Darimo T1 350mm 27.2mm           116g    279EUR    2.4
Hylix 400mm 27.2mm               48g     62.7EUR   1.3
Gelu g.2 saddle                  91g     270EUR    2.96
SRAM XG-1199 10-42               139g    257.5EUR  1.84
Magura MT-8                      168g    394EUR    2.34
MT ZOOM Ultralight clamp 31.8mm  15g     21.3EUR   1.42
RD-M9000                         95g     167EUR    1.75
Prices are from r2-bike, ebay and manufacturers, with VAT.
TheRookie
by TheRookie
Realistically you need to set your budget and work out the best weight savings you can get for that budget.
As noted above there are a fair few options and I'll add in Bars (circa 120-130g is fairly easy) and tyres (depending on surface).
UpFromOne
by UpFromOne
You mention Mt Zoom, don't overlook their flat bars either, you can save 70g there.
EPICBYTES
by EPICBYTES
I would upgrade crankset and pedals. Since they are rotational weight and you will feel more difference in performance especially uphill.
RaceFace Next SL (445g) can be found for $250
M9000 XTR race pedals 310g can be found new at $80. (I got mine for $74 new at backcountry)
Splurge rest of your budget on Mt.Zoom bars, and maybe new headset.
d36
by d36
Including build costs I can get dt swiss 350 hubs, rims and spokes for approx $700 (looking at around 28mm internal and mid range spokes)
Theres also prebuilt wheels like these for a bit cheaper but i haven't found much on powerway hubs
https://www.aliexpress.com/store/produc ... 0.0.pvhrCW
Lelandjt
by Lelandjt
d36 wrote:Including build costs I can get dt swiss 350 hubs, rims and spokes for approx $700 (looking at around 28mm internal and mid range spokes)
At first that wheelset looked like a good deal but that weight isn't great. 28mm is wider than you need. Try to find a narrower, lighter rim. I wouldn't be shy about using those (or other generic Asian) hubs. Everything I've seen for the last 5 years has been solid but find the weight on them so you know you're not buying boat anchor hubs. BTW, Pillar 1420 spokes are good. They're copies of CX-Ray/Aerolites and nearly as light.
02GF74
by 02GF74
pedals for sure.
Front q/r maxle - get one that is done up using allen key.
Chain: kmc x11sl
SRAM 42-10 cassette about 100g less but needs to have XD driver; your wheels may not be compatible
SRAM X01 derailleur and shifter are lighter than Shimano.
d36
by d36
Well my budget is blown!
The xpedo pedals were on sale so I splurged
I ended up going for 25mm internal on 350 hubs ($575 inc postage)
On paper should be about 1500 depending on rim weight
I feel a bit better knowing that the hubs will be easy to service
Replaced bits of my headset as suggested
Cut my steerer and seatpost
Bike should be just below 9.3 kg now
