Do you shorten the hose for disc brakes when they are bought
stockae92
by stockae92
Wondering if you would shorten the hose for the disc brakes when you are buying them new? The brakes are usually come in ready to roll. Cutting the hose will need to be rebleed, right?
Hamfist
by Hamfist
What brand are you referring to? With Shimano, you can cut them and connect without re-bleeding. The olive is already in the lever. Caveat - I've only done XTR and this was the case.
wingguy
by wingguy
If the choice is between shortening them or riding with two giant loops of brake hose in front of the handlebar which would you prefer? :wink: Many brakes will barely lose any fluid and will run ok straight off, though a quick lever bleed to get rid of any air is a good idea.
(And obvs, if your bike has internal routing you'll need to redo the rear brake anyway.)
bumpkin
by bumpkin
I was able to shorten my SRAM guides with no bleed. They seem fine.
TheRookie
by TheRookie
Shorten, this is weight weenies after all!
DeeHubbs
by DeeHubbs
ALWAYS! Sloppy cable routing is my biggest pet peeve on bikes. No matter how nice or bling your bike is, I cant look past sloppy or poor cable routing.
Dirtperson
by Dirtperson
+1 for shorten and bleed. Brakes aren't the thing to save time by cutting corners.
Steve_W
by Steve_W
Shorten, don't be afraid to rebleed, it's dead easy....I forget the kit I bought, it came with really useful step by step instructions.
Xtr setup
Juanmoretime
Administrator
by Juanmoretime
Shorten and rebuild. I've done it with Formula brakes and Shimano brakes. Xt and XTR are a breeze to cut. I didn't need to bleed after I shortened with the Shimano's just replaced the olive and barb. I bled them anyway since it takes less than 10 minutes to bleed both sides.
RESIDENT GRUMPY OLD MAN.
KWalker
by KWalker
What was your experience with formulas?
Gramz
Failed Custom Bike
TheRookie
by TheRookie
I'll chip in as I'm also running Formula.
There is a knack to bleeding them correctly, if you bleed as if they were other brands they end up under filled, the diaphragm has some 'pre-load' so once you've bled it you then need to push more fluid in to fill up the reservoir controlled by the diaphragm against a small amount of load (really small by the way) before removing the syringe and fitting the plug.
02GF74
by 02GF74
Always, it is not just about weight but I cannot stand long loops of hose dangling. Sometimes you can get away without having to bleed them.
I also adjust the angle of the hose entry to the callipers by undoing the banjo bolt just enough to rotate it, then retightening it.
The same applies to gear shifter cables.
