27.2 mm dropper post?
the_marsbar
by the_marsbar
The Specialized dropper post that I am running is still great. I can only recommend it.
muntos
by muntos
Hi marsbar, I'm thinking also to the XCP dropost for my F29 Carbon 1, you said that on your FSI you routed the internal cable just near BB and then outside through a little hole, do you know if this works also on F29 frames (sorry, I have the bike somewhere else for the moment and can't check exactly what are you saying) ?
the_marsbar
by the_marsbar
I'm sorry, I don't know. But what you can do is check the manual (available in PDF on Cannondale website). It should show a picture of the frame, and it's features.
muntos
by muntos
Correct, I've checked the F-Si owner manual and noticed the hole for the Di2 which I don't have on F29...Sucks...
Sent from my SM-G935F using Tapatalk
TheRookie
by TheRookie
Should knock a gram off the frame weight as well!
muntos
by muntos
TheRookie wrote:Should knock a gram off the frame weight as well!
Don't tempt me :D :D !
muntos
by muntos
A solution would be to use the route for the front derailleur (I'm on XX1), the question would be how to fix the cable housing without those blockers (I don't know how they are called) that would come from the dropper down to this hole for the derailleur...
TheRookie
by TheRookie
You could use the top tube cable routing and drill out the cable end stop to make a seat tube guide.
commendatore
by commendatore
muntos wrote:A solution would be to use the route for the front derailleur (I'm on XX1), the question would be how to fix the cable housing without those blockers (I don't know how they are called) that would come from the dropper down to this hole for the derailleur...
This is what I did with a Thomson post on a Superfly SL. Routing the cable took some patience since you have to feed it reverse of the normal direction but it was doable.
joshpeck
by joshpeck
Brand x makes a 27.2 post. Inexpensive, 2 yr warranty, and light enough.
oskarbike
by oskarbike
Please visit our webiste :)
http://jbg2dps.com
addict
by addict
anybody knows carbon dropper's price and reliability?
the_marsbar
by the_marsbar
My Specialized XCP is still going strong.
