Cannondale FSi builds
prebsy
by prebsy
I ride the same exact height and went with the large. You can see what it looks like a few posts up.
grover
by grover
I ride 747mm saddle height, 55mm setback.
I'm 182cm.
Ride a large with 90mm stem.
ChrizZZz
by ChrizZZz
183 / 75.5cm / offset 55mm / 90mm Stem
And i ride Medium!
sefton
by sefton
I have a f29 carbon.
I have ordered the stuff to go 1x11 but I have just seen this post.
I have ordered an Absolute Black sram gxp (6mm offset)
will this foul the chainstay then?
will a sram 11speed cassette work ok on the original rear 10sped hub?
ChrizZZz
by ChrizZZz
Depends if the hub is 11 speed compatible!? But i dont think so.
What Crank are you using? there are different axles.
dub
by dub
Since this is where all the F-si folks are lurking...trying to comprehend all this new crank/bb lingo
Building up a 2010 Flash hi-mod frame. Want to put a RaceFace Next SL G4 cranks on there. As it has a 30mm spindle it will work fine with a bb30 bb, right?
LeDuke
by LeDuke
Yes.
Sent from my XT1585 using Tapatalk
rycki
by rycki
Hi,
My friend's FSI after a race.
On a trail in some moment he felt something like a flat tire. He stopped and looked at the wheel, was fine. Checked the QR and tried ride further, but still felt something wrong.
Stopped again and then he saw the cracked frame.
The frame in theory is under warranty, but distributor for Central Europe - Aspire Sports (Czech republic), based on pictures said that was a mechanical damage - no warranty :(
Cheers
stockae92
by stockae92
shooooooocking! Big brand manufacturer blames cracked frames on crashes or component failure. If you have a Cannondale bike shop around, maybe bring the frame to them and see if you can get some leverage on the warranty claim.
stoney
by stoney
I'm sorry but it does look like the result of an impact.
ChrizZZz
by ChrizZZz
stoney wrote:I'm sorry but it does look like the result of an impact.
Ive got the same opinion.
There are some similar frames:
--> https://www.facebook.com/CarbonBikeService/?fref=ts
the_marsbar
by the_marsbar
I've heard about a frame being warrantied with a crack at the same place....
gfeldy
by gfeldy
Just wanted to say I'm happy to see this thread is still running strong.
~GFeldy~
S Works Tarmac w/ EPS
S Works Epic HT Blurple tuned
Kitsbow
S Works Epic Blurple tuned - Sold :doh:
FS-i - Sold
Scalpel custom - Sold
EVO - Sold
roeman
by roeman
What are the options regarding aftermarket wheels for the FSi? Do you need to have wheels customs built by a wheel builder with 6mm offset? Or do some manufactures make FSi specific wheel-sets?
Cheers
Giant XTC Team 2014
Giant TCR Advanced Pro 1 2016
Cannondale Scalpel Si 2018 Team
Cervelo S5 Dura Ace - Enve 4.5's
the_marsbar
by the_marsbar
Custom wheels is the way to go (shops will also build them for you, if you say it's for an F-Si). Check out my bike, one of my friends helped me build the wheels on it. No big deal :)
