Cannondale FSi builds
ElectronicFur
by ElectronicFur
Just got retired my 18 year old Kona & replaced it with a 2016 team FSI :)
Now what is the best way to go tubeless on my Enve M50 rims? I've not done tubeless before.
And what width of rim tape do I need for that?
Cheers,
EF
ChrizZZz
by ChrizZZz
https://www.youtube.com/watch?v=mZ1I9seP1iw
U have to use the Enve-Tubeless Tape (Gorilla-Tape)
Put in the Tubless-Valve (Should be all with the Bike ;) )
Put on the Tires with about 100ml of tyre-sealent.
U will need a compressor. The Enve Rims are not the best to pump it up with a normal floorpump.
REALLY IMPORTANT!
RIDE IMMEDIATLY
ElectronicFur
by ElectronicFur
ChrizZZz wrote:https://www.youtube.com/watch?v=mZ1I9seP1iw
Thanks Chriz. Are you saying the Enve tape and valves should have come with my bike? I didn't get any with it.
the_marsbar
by the_marsbar
I'd use Notubes tape or similar instead. It's lighter :)
ElectronicFur
by ElectronicFur
the_marsbar wrote:I'd use Notubes tape or similar instead. It's lighter :)
How do I work out which width I need for my Enve M50 rims?
the_marsbar
by the_marsbar
21 mm wide tape is recommended for their Crest rims (http://www.notubes.com/Stans-Rim-Tape-1 ... m-P54.aspx), so I'd go with that.
ChrizZZz
by ChrizZZz
The Notubes and similar tapes didnt work 'out of the box' with the carbonrims.
AND YES, this should be delivered with the bike!
Ask the dealer! :!:
the_marsbar
by the_marsbar
What do you mean? Notubes tape worked fine on my ENVE 29XC rims, and Mcfk rims too.
ElectronicFur
by ElectronicFur
ChrizZZz wrote:The Notubes and similar tapes didnt work 'out of the box' with the carbonrims.
Ask the dealer! :!:
Thanks, I've emailed my dealer to ask about it.
Just in case my dealer doesn't provide me with the Enve valves and tape, what did you have to do the make the other tapes work?
ChrizZZz
by ChrizZZz
the_marsbar wrote:What do you mean? Notubes tape worked fine on my ENVE 29XC rims, and Mcfk rims too.
Really? It doesnt glue on the matt raw carbon structure. :noidea:
Tune and notubes didnt hold the air.
On my old roval control rims i put a thin layer of clear coat (normal spray can) After thaat i had no problem.
ChrizZZz
by ChrizZZz
If someone is interested in frameweights:
- 54g bearings steering
- 86g bottombracket Ceramicspeed PF4630
- 50-60g guardtapes+Slappertape
- 20-40g decalkit Blau/Silber ca 20-40g
___________________________________
frameweight: ca. 905-935g
LAN
by LAN
What is the distance between the chain stays where the tire sits?
Looks to be 80mm+ from the last picture, will it fit 650b+ tires?
rschenkels
by rschenkels
Hi,
I ordered 2 handmade carbon wheel sets for my FSI Carbon 1 with the official 12mm offset, both with dt240s hub, but after mounting them this is a bit too wide. 10mm offset is ideal according to me, just to let you know my experiences.
One set laced on Duke Lucky Jake rims, another on Nox Skyline rims.
Ron
ChrizZZz
by ChrizZZz
Who has mounted a 34 Teeth Oval Directmount Chainring?
Which one fits?
Garbaruk doesnt fit. (only 32t)
Vicpt
by Vicpt
ChrizZZz wrote:Who has mounted a 34 Teeth Oval Directmount Chainring?
Which one fits?
ChrizZZz, i have a 34t Garbaruk oval on mine!
