LOOK 695 C Stem Swap
roadrider22
by roadrider22
I have a brand new 2011 Look 695 C stem, 100-110mm adjustable in the matte carbon red pin strip color and would like to swap for a 90 or 90/100mm version. Anyone need a longer C stem and have a shorter???
sammo
by sammo
I may have one at home - I'll check the size...mine is white and black. I need a 120mm so if you come across one let me know. Cheers Sammo
roadrider22
by roadrider22
OK thanks, I will wait to hear from you.
sammo
by sammo
Hi there, sorry mine is the same size as the one you currently have. Have you found an online stockist that sells these? I still need a 120mm. Cheers
roadrider22
by roadrider22
I may have a 110/120 (2011 model with insert allowing either 110 or 120) in matt nude carbon with red pin stripe.
velofan
by velofan
I have a c-stem 110/120 (with the insert) in gloss nude carbon with red pinstripe. I need to trade for a 90/100 model. Anyone interested? Mine is in perfect condition on my new Look 695.
Thanks.
notsoswift
by notsoswift
These stupid stems are actually what stopped me from buying a 695, I needed 14cm for a XXXL... and they only go up to 13 on XXL = 2.5 cm too short
Still, made the decision to get a custom Cyfac easier!
Tumppi
by Tumppi
You can always put normal stem instead of C-Stem and I know few Look 695 owners who has done it. One example needed -17 degrees 130mm stem to get saddle handlebar drop suit his needs and He change C-stem for 3T one. For me C-stem adjustment is in fact useless because I have tilted down the stem minimum -9 degrees position and cut off fork 15mm and removed the spacer. I can't get the stem lower, but it is just perfect now. Lucky me.
