Dura Ace 9000 - ETA late 2012/early 2013
KLabs
by KLabs
rei14 wrote:Just picked up my DA 9000 shifters hoping that it'll work with my current 10 speed components. I wasnt happy with the ergonomics of the 6700/7900 shifters so I just stuck with the 6600 until the 9000 came out.
List of Components:
9000 shifters
7900 crankset (compact)
7900 rear derail
7800 front derail (braze on)
6700 chain
6600 cassette (12-27)
1. Front derail works great with the shifter. Didnt have any problems shifting at all. Cant really tell if the shifting is better than the 6600 since I rarely shift on that side.
2. Rear derail was another story. It just wont shift to the 13t and it kinda rubs the 14th teeth. Other than that it shifts fine throughout the other gears. Most of the time I have it on the 15t so this is not a problem for me. Overall I'm pretty happy with the performance.
Interesting that the 9000FD STI works with the 7800 FD ... which would mean that it has a different actuation ratio to the 7900 FD ...???
The 9000RD STI and 9000 RD apparently has a different actuation ratio to the 7800/7900 RD.
Perhaps you should try the 9000 chain, it may just work for 13t and better for 14t ...
petal666
by petal666
I picked up some C35 Tubulars. Decals are under clear coat this year.
rei14
by rei14
Unfortunately, I dont have a 6700/7900 FD that I can do a test. My friends are not willing to remove their FD for me to experiment :). I have the 9000 chain on order hopefully that fixes the issue with the rear. Will post back with my findings with the new chain. I was able to shift 11 times with the rear shifter but the 7900 RD wont go beyond the 10th cog (wanted to see if it actually worked).
edesigner
by edesigner
Wingnut wrote:IMO the exposed area makes the levers look cheap...
..should come with a label that says "cyclocross riders beware" :shock: Maybe they are sealed pretty well but that's not something I am loving seeing that.
maxxevv
by maxxevv
KLabs wrote:Interesting that the 9000FD STI works with the 7800 FD ... which would mean that it has a different actuation ratio to the 7900 FD ...???
The 7800 STi would work with the 7900 FD, but not the 7900 STi with the 7800 FD. Due to the lack of a mid-position indentation in the 7900 Sti.
The 9000 STi has some specific ratio or spring design implementations that allow for a constant actuation force throughout the stroke. How this affects its compatibility with either 77800 or 7900 Sti, I haven't had the chance to try yet. So it may be the reason that it is not completely compatible with the 7900 RD.
For 'perfect shifts' .. definitely go with the 9000 RD.
jeffbong
by jeffbong
my DA 9000 just arrived today at my LBS. will be fixing it soon...:)
the shifter
the crankset
BB
Hopefully it is good...:p
MarkThailand
by MarkThailand
There have been some posts about the incompatibility of the Compagnolo SR 11-speed casettes with the Shimano 9000 11-speed hubs and vice versa. I am also going to assume that the Shimano 9000 shifters will not work with Campagnolo 11-speed cassettes and vice versa for the Campagnolo SR shifters and Shimano 9000 11-speed cassettes also.
But, I was wondering if the Campagnolo SR cramkset work with the rest of the Shimano 9000 11-speed groupset?
Mark
toiyuet
by toiyuet
MarkThailand wrote:There have been some posts about the incompatibility of the Compagnolo SR 11-speed casettes with the Shimano 9000 11-speed hubs and vice versa. I am also going to assume that the Shimano 9000 shifters will not work with Campagnolo 11-speed cassettes and vice versa for the Campagnolo SR shifters and Shimano 9000 11-speed cassettes also.
Mark
The owner of this bike say YES.
http://i1223.photobucket.com/albums/dd5 ... 3654_1.jpg" onclick="window.open(this.href);return false;
Foghat
by Foghat
thisisatest wrote:KMC has their current 11speed link right now. I would assume it is compatible until I hear otherwise. KMC lists their 11speed chain as compatible with DA9000 now.
KMC seems to have removed the earlier reference to Shimano 11-speed compatibility from its webpages for the M/L 11 connecting link and the X11SL chain.
How are people joining their 9000 chains, and with which tools?
Freight-train groove-ride: 4'02" to 14'40" LOUD, bass right up and eyes closed!
upside
by upside
I used the Park CT-3 tool and used the pin that came with the chain. I prefer the link, but was unaware of any when I built the bike. So far so good.
wingguy
by wingguy
rei14 wrote:Just picked up my DA 9000 shifters hoping that it'll work with my current 10 speed components. I wasnt happy with the ergonomics of the 6700/7900 shifters so I just stuck with the 6600 until the 9000 came out....
I don't mean to be rude - but I don't get it.
What are you gaining from the 9000 levers that is more important than having a drive train that works? :noidea:
Foghat
by Foghat
Thanks upside - I have a Park CT-3, so that's helpful to know.
thisisatest
by thisisatest
Foghat wrote:KMC seems to have removed the earlier reference to Shimano 11-speed compatibility from its webpages for the M/L 11 connecting link and the X11SL chain.
Hmm... Interesting.
Thanks for the update, I will try to look into it.
rei14
by rei14
No worries... I just did it because I want to and I wanted to upgrade my 6600 shifters :D. If I couldn't get the shifters to work with the larger cogs then I would have gone back to the 6600 shifters. I cant get myself put down the money for the complete 9000 groupo... This will do the job until the Ultegra 11 speed stuff comes out. I'm happy with just using 12,15-27T. Now I dont have to worry about upgrading the shifters. The increase in brake power over the 6600 shifters is very noticeable (using 6700 brakes w/ swiss stop pads). This made it worth it for me.
Horacio
by Horacio
I just ordered an X11SL chain for 2013 11sp DA from Fairwheel. I made sure it was compatible and they confirmed. I havent installed it yet, but would love to know if it is in fact useable.
