It is currently Sat Nov 25, 2017 8:58 am
Post new topic  Reply to topic  [ 177 posts ]  Go to page Previous 13 4 5 6 712 Next
PostPosted: Mon May 28, 2012 7:04 am
Tubes lose pressure every day, latex more so than butyl. I pump up every day. I like the same psi all the time.
I used to ride Conti tires a lot, then switched to Michelin for a while. Just tried the new Specializes Turbo pro tires. You guys should give them a try. Really not bad at all and price is cheaper than the other high end clinchers.
PostPosted: Mon May 28, 2012 2:25 pm
drmutley wrote:
Which butyls u use that are close to latex? Would like to try them!
I switched to latex a couple of years ago and won't prob ever go back to butyl, as the positives far outweigh the (1) negative.
Having to put 10 to 20psi into them each day is a small effort when u consider how much better they roll, the added puncture resistant they are, and the fact that they tend to never go immediately flat when u do happen to flat. Nothing worse than the instant butyl flats at high speed, where latex will more often than not just slowly deflate, allowing for safe stopping (ESP on front flats).
Are you sure about all that?
PostPosted: Mon May 28, 2012 4:51 pm
FWIW I would take Mich ProRaces over the Contis every time ....
PostPosted: Mon May 28, 2012 5:03 pm
Because?
PostPosted: Mon May 28, 2012 6:27 pm
Schwalbe are adopting a similar anti-puncture strip to Conti for the new Ultremo ZX, and releasing a Road Tubeless version. Interesting!
http://www.bikeradar.com/road/news/arti ... nch-34116/
PostPosted: Mon May 28, 2012 6:32 pm
Very sure from my couple of years experience on latex
PostPosted: Mon May 28, 2012 6:41 pm
My experience is different, and a fair number of people on this board with decades of experience riding would not choose latex tubes plus clincher tyres for the mountains. Likewise, some manufacturers of clinchers explicitly state not to use latex tubes with their wheels. I wonder why?
Tubs utilise the benefits of latex safely. Latex and clinchers are problematic precisely because they are so elastic.
This has been debated a fair bit on this forum ... if latex and clinchers works for you then fair enough.
PostPosted: Mon May 28, 2012 7:41 pm
shokhead wrote:
Because?
Because they wear and grip better that's why
PostPosted: Tue May 29, 2012 12:39 am
giant man wrote:
shokhead wrote:
Because?
OK!
PostPosted: Tue May 29, 2012 2:20 am
Here's a question. I have seem both flat/smooth and rocky/rough tarmac in different countries. Do you think flat protection depends on the road surface?
PostPosted: Tue May 29, 2012 2:32 am
The best I've tried are Panaracer R'Air. I cleaned out the stock here in the states last year, and contacted the distributor and bought some of the last that they had as well (they were completely out of 60mm stems, which is what I wanted most, but still had a few 48s).
Still, I got enough that I should be good this year. These tubes can go three of four days without losing significant pressure and ride very close to latex. If I can't find them in the future, I might have to give latex another shot (but they better not loose more than 15 psi in 10 hours, or I won't like them).
PostPosted: Wed May 30, 2012 10:21 pm
http://www.cyclingweekly.co.uk/tech/gea ... -tyre.html
http://bicyclesportshop.wordpress.com/2 ... rse-tires/
http://www.competitivecyclist.com/revie ... e_295.html
http://roadcyclinguk.com/news/racing-ne ... -4000.html
PostPosted: Thu May 31, 2012 12:11 pm
I'll assume that's not a rhetorical question and venture an answer. It's because latex tubes are more vulnerable to heat than butyl and in clinchers the tubes lack the all round protection of tubs.
r o y g b i v
PostPosted: Thu May 31, 2012 12:37 pm
It was a rhetorical question but yes.
PostPosted: Thu May 31, 2012 1:04 pm
Yes, the Panaracer R'Air are very good and keep air pressure well. that is what I use with clinchers :-)
There are no new unread posts for this topic. Michelin Pro4 Tubulars
russianbear
Mon Feb 27, 2017 7:51 am
superdx View the latest post
There are no new unread posts for this topic. Michelin Power Endurance 28mm
shoemakerpom2010
Fri Mar 31, 2017 12:45 pm
shoemakerpom2010 View the latest post
There are no new unread posts for this topic. Michelin Comp, killing sidewalls!
PLuKE
16
1309
Sun Jul 16, 2017 8:43 am
Stolichnaya View the latest post
There are no new unread posts for this topic. Conti GP4000 28mm on 2016 Supersix Evo
nick312
11
1009
Sat Aug 12, 2017 5:02 pm
Ltoddokc View the latest post
Users browsing this forum: Baidu [Spider], PinaF8 and 33 guests
