It is currently Tue Jan 23, 2018 1:28 pm
Post new topic  Reply to topic  [ 39 posts ]  Go to page 1 2 3 Next
 Post subject: Dugast Tubulars
PostPosted: Thu Oct 06, 2011 2:28 am
I'm thinking of getting some Tubulars but, I'm not sure if I should get a Rhino XL or a Fast Bird or maybe even one and one?
Looking forward to some opinions.
 Post subject: Re: Dugast Tubulars
PostPosted: Thu Oct 06, 2011 9:25 am
Need to know a few things first, such as:
- Are you exclusively using the tyres for XC racing?
- What terrain do you ride in, i.e. hardpack, wet/loose?
- What rims are you using?
:wink:
Norwood & Adelaide Uni CC
PostPosted: Thu Oct 06, 2011 9:59 pm
-I will be riding Cross Country only.
-Where I ride it's usually dry, rocky, and hardpacked.
-I will be riding Drc tubolite rims.
PostPosted: Thu Oct 06, 2011 10:02 pm
Fastbirds. Just felt them, never tried. But used Rhino XL. The good thing with Fastbirds is that the thread are much wider than Rhino where you only have threads in the middle. Should be better for cornering, roots and more.
/jonas l
PostPosted: Thu Oct 06, 2011 10:12 pm
Do you think I should get a wider fastbird in the front and a thinner one in the back? Like a 50mm in the front and a 48mm in the back?
PostPosted: Fri Oct 07, 2011 11:32 am
Dugast also makes tyres with a 3rd party thread on it. If you're really in doubt and know what tyres suit your riding the best I suggest giving them a call.
Ride it like you stole it
PostPosted: Fri Oct 07, 2011 11:52 am
Yes, they do, but there could be a significant weight penalty. According to a Bike Mag test a while ago, they just cut off the sidewalls of the tires the customer supplies. What you end up with is an extra layer of casing. That layer is not there if you use Dugast's own tread, which is produced for the purpose.
PostPosted: Fri Oct 07, 2011 11:22 pm
I actually like the dugast thread. It's just that I don't know which one to use. There isn't really a problem with me since I'm a 100lbs/45kg and, I'm a pretty small rider. So, thin tires wouldn't be a problem.
PostPosted: Sat Oct 08, 2011 8:04 am
why not use 48mm front and rear if you're that light? I'm 60kg and used 47mm Rhinos before, enough volume for me. Uses Tufo XC2 Plus at the moment as they came with the wheels I bought
/jonas l
PostPosted: Sat Oct 08, 2011 12:27 pm
You mean 48mm Fast birds?
PostPosted: Tue Oct 11, 2011 8:16 am
yes, meant fast birds
/jonas l
PostPosted: Tue Oct 11, 2011 8:44 pm
That could work. Thanks!
PostPosted: Thu Oct 13, 2011 5:46 am
We've been using a pair of Tufo XC2 plus tubulars and these have been good so far. They rolled very well over hard surfaces.
Strada Hand Built Wheels
http://www.stradawheels.co.uk
PostPosted: Thu Oct 13, 2011 12:43 pm
+1. I love all of my Dugast tires, but this isn't a road/track/'cross application. I had received my tubular MTB wheels from Tufo pre-glued with (of course) Tufo tires. I was not expecting to like them as much as I do, but they are fast and durable. What more do you want in an MTB tire?
PostPosted: Thu Oct 13, 2011 1:44 pm
Geoff,
I'm not really interested in Tufo, All I want is Dugast's white sidewalls on my bike! :thumbup:
So, it's pretty much Rhino XL or Fast Bird.
There are no new unread posts for this topic. dugast tread separation
in Everything wheels
sungod
Thu Aug 24, 2017 4:18 pm
sungod View the latest post
There are no new unread posts for this topic. Ridley X-Night 50, Dura Ace Di2, Shimano C24 tubular, Dugast
kolarzyk
Mon Oct 23, 2017 12:06 pm
kolarzyk View the latest post
There are no new unread posts for this topic. Help me get some tubulars
zalle
32
3011
Fri Mar 10, 2017 2:51 pm
Geoff View the latest post
There are no new unread posts for this topic. Want to try TUBULARS
53cxzero
22
1808
Tue Nov 28, 2017 1:10 am
53cxzero View the latest post
There are no new unread posts for this topic. open tubulars
bennybikes
Fri Nov 03, 2017 4:36 am
vanillaflyweight View the latest post
Users browsing this forum: No registered users and 3 guests
