It is currently Fri Nov 24, 2017 3:22 am
Post new topic  Reply to topic  [ 31 posts ]  Go to page 1 2 3 Next
PostPosted: Wed Aug 24, 2011 3:56 am
Can some one please advice me on a good floor pump that has a pretty accurate psi gauge.
My specialized is on its way out=(
thank you
PostPosted: Wed Aug 24, 2011 4:01 am
My Lezyne Alloy Floor Drive is always within 1-2 PSI of my SKS digital gauge, at both road and mountain bike pressures, and I've had it almost two years. Pretty darn accurate in my book.
PostPosted: Wed Aug 24, 2011 4:11 am
technically, no pump really measures the tire's pressure unless something in the head is actively holding the valve pin down. (like a screw-on schrader valve head).
if you want a really accurate gauge, try one of the ones used for auto racing. available in different ranges, even just 0-15psi
PostPosted: Wed Aug 24, 2011 12:25 pm
I have one as well, its the best pump I've had, I like the screw on head very useful and precise.
PostPosted: Wed Aug 24, 2011 1:16 pm
thanks guys, Lezyne it is!
PostPosted: Wed Aug 24, 2011 3:42 pm
Topeak also make a digital pressure gauge. Good Xmas present.
PostPosted: Wed Aug 24, 2011 3:54 pm
I'm a mechanical engineer, and I work for a company that has an agressive QC system and regular certified calibration of all measuring instruments. So, naturally, I was also skeptical of the accuracy of cheap pressure gages for both my car and bike.
Since pressure gages are cheap, I bought about 6 of them, and I also have two pumps with built-in gages (Silca and Joe Blow)
I then pumped up a tire (repeatedly) and immediately compared all the gages to each other. The surprising result was that, to within my ability to read the gages, all of them read exactly the same.
I know this isn't proof that all of them are accurate. But it satisfied me that most, even very cheap gages, are actually pretty accurate. Certainly accurate enough for me to use on bicycle tires. So if you just compare a couple gages and they are the same, you are probably OK. Of course you could also send your gages out to a local test certification laboratory. They are in nearly any reasonable-sized city.
PostPosted: Wed Aug 24, 2011 9:10 pm
I like the new Topeak digital SmartGauge D2 because it allows you to read the pressure in real time as you let air out with the release button on the gauge. So slightly over inflate your tyre with your floor pump, measure the pressure with the Topeak gauge, press the adjust button while keeping the gauge on the valve, and then gradually release pressure.
Very easy to get within 1 psi of your target. Not sure if the gauge is as accurate as that, but seems to be consistent which is what counts for me - once I find the road feel I like, I can replicate it using the same observed pressure reading.
Cheers
GJ
PostPosted: Thu Aug 25, 2011 12:38 am
i didnt realize this was in the ROAD section, my bad.
some crossers and mtbers look for pressure changes of 1/2psi...
i like the topeak gauge too, but find it's too easy to release a good amount of air when putting it on the valve. i like the sks airchecker better for that reason. also, you dont have to switch anything when going from presta to schrader, and most importantly, it's lighter!
PostPosted: Tue Mar 27, 2012 10:07 am
I have just got the Lezyne alloy floor pump and I'm quite struggling with screwing the Presta head into the valve. I have a valve extender on my aero wheels and I find it difficult to screw in the Presta head, it basically turn the extender instead of just screw on top of it down. Also when I tried to screw it out, it turned the extender out of the tyre valve.
Any recommendation how you use it? I guess I'm doing something wrong..?
PostPosted: Tue Mar 27, 2012 11:19 am
Silca used to be good but quality not there now. Lezyne alloy floor drive is good. Just make sure you tighten the remove able valve cores a bit to avoid undoing one in error.
Sent from my A500 using Tapatalk
N+1 It Never Stops
PostPosted: Tue Mar 27, 2012 12:11 pm
I don't know what people like about the Lenzyn, as there is nothing easy about using it. If you use a pump a lot like I do, then you'll likely want something quick, reliable and accurate. There are several good pumps on the market (SKS Airbase, Nashbar makes a good one, etc).
Having said that, I've heard remarks lately that Lenzyn is putting a quick release head on their pumps now and if you just purchased one, they will refit the head. You might want to contact them about this.
PostPosted: Tue Mar 27, 2012 12:38 pm
For the UK guys I'd recomend Halfords own track pump.
metal
Gauge at top so you can see it
Head fits schraderand Presta with no swapping
Reliable
£28
Work well enough to even pump the monster tyres on my Landrover up 265/75-16's so huge
Pump to 150 easily, 110 one handed
I run a small bike workshop so pump a LOT of tyres, I have 2 of these in the workshop and 1 in the van and they are dependable (7 years old the oldest at moment) and work better than any pump I've ever owned. Guages are spot on. Lovely not having to worry about the valve type
They even hold on stupid valve extenders!!!!
http://www.halfords.com/webapp/wcs/stor ... yId_165661
Cervelo S3 2011. Blinged 6.718 Kg
PostPosted: Tue Mar 27, 2012 2:54 pm
I've had a Silca Pista for over 25 years...after very heavy use during that time the gauge is till perfectly accurate and I have only had to change the leather and grommets every 7-8 years. Best tool investment ever!
EM3
______________
PostPosted: Tue Mar 27, 2012 3:09 pm
The OP has probably already found a pump, but my Giant Control Tower Pro is the best pump I've ever used. Accurate guage, tons of pressure per pump and better than any Joe Blow, Specialized, Blackburn, Lezyne or Silca I've ever used. I inflate my car tires with mine with no problem.
There are no new unread posts for this topic. Topeak pump with screw-on/different branded pump head?
Mep
Sat Apr 15, 2017 4:49 pm
Mep View the latest post
There are no new unread posts for this topic. Which is more accurate, generally, smart trainers or crank based power meters?
Shrike
15
1296
Mon Mar 27, 2017 12:38 am
HakeemT View the latest post
Users browsing this forum: 5DII, Succisa75 and 37 guests
