It is currently Tue Jan 16, 2018 4:54 pm
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Mon Aug 22, 2011 10:27 pm
I'm building up a Specialized CruX frameset with Avid Shorty Ultimates and wheels with Velocity A23 rims. I have read that in the narrow position the Shorty Ultimates do not work with very wide rims like the Zipp 303 (26mm). As I understand it the A23 (at 23mm, go figure) are not quite as wide. Anyone used this combo and had a problem?
Thanks.
PostPosted: Tue Aug 23, 2011 3:42 pm
I don't have a problem with the loaner 303 I used but will check again. I also ran with the narrow setup front and back.
PostPosted: Tue Aug 23, 2011 6:15 pm
I don't have any first hand experience, but both Katie Compton and the Cannondale-Cyclocross World team were using Avid shorty ultimate brakes in the narrow profile with zipp 303 wheels.
http://www.bikeradar.com/news/article/p ... eam-28035/
PostPosted: Wed Aug 24, 2011 1:25 am
Running Shorty Ultimates in narrow configuration on Revolution WW 23 mm wide aluminum rims. New build, but so far no problems.
PostPosted: Wed Aug 24, 2011 8:43 am
I use HED C2s on my Crux with Shorty Ultimates in wide mode. Helios told me how to do it, but basically you run the brake shoe with the spacers behind the brake arm mount, and not like the directions say. They also make a low profile pad holder.
PM me or Helios if you have any questions.
PostPosted: Thu Aug 25, 2011 3:46 pm
I'm running the narrow Shortys with A23's with absolutely no problems.
http://eatrideworksleep.tumblr.com
PostPosted: Tue Nov 01, 2011 2:51 pm
I thought I would follow up on this post.
I found that I could use the Major Toms and A23 with the Avid Shorty Ultimate in the narrow profile on the rear of my Crux with no issues. In the front and and in the narrow profile setting with the pads adjusted to the lowest point, I found the brake pads contacted the wider rims a little high, with the pads hitting the rim at an 45 degree angle. I ordered at set of SRAM Rival Brake Pad Holders. I got a much better placement of the pads on the center of the brake track and the pad contacted the rim with the flatter profile.
It looks to me that Ryan Trebon has a similar issue on his Felt in this article. http://www.bikeradar.com/news/article/pro-bike-ryan-trebons-felt-f1x-32057
"Ryan Trebon (LTS Felt) has both the front and rear Avid Shorty Ultimate brakes set up in the higher-power position. Road pad holders are used instead of the stock units to better fit the wide-profile Zipp 303 rims"
PostPosted: Tue Sep 17, 2013 6:38 pm
Resident master of GIF
jmh wrote:
AHHHHH this is what i neeeeed!!!!
Nate ★ Life , my tumblr joint
Instagramz
My Podcasts
PostPosted: Thu Sep 19, 2013 1:22 am
Shop Wrench
Avid sells a thinner pad holder setup for zipp type wheels, i think its called shorty ultimate carbon rim pad kit or something along those lines. The road setup works too like you found!
PostPosted: Fri Sep 20, 2013 5:48 pm
yea got the rival shoes in and realized i had the issue in the rear as well!
so i donated a pair of my sram red holders for cross season. Anywho.... flipped the supplied spaces from AVID works ONLY if you run the wide position.
like the way it's supposed to be looking out to in is..... bolt-> adjustable washer-> spacer->avid brake->bigger spacer-> adjustable washer->shoe
in the wide position i was able to accomplish the same thing (without rival shoes) by doing bolt-> adjustable washer-> spacer -> bigger spacer-> avid brake-> adjustable washer-> shoe
but i wanted to run narrow narrow, so needed the rival shoe anyways.
Instagramz
My Podcasts
PostPosted: Fri Oct 11, 2013 1:57 pm
yup did this mod. WORKS!!!! love it. been looking for this answer for a while too. thanks W-W!
Instagramz
My Podcasts
PostPosted: Fri Oct 11, 2013 4:36 pm
So if you all replaced your Shorty Ultimate brake shoes with SRAM Rival shoes, does anyone want to sell me a pair of Shorty Ultimate brake shoes :) ?
Cannondale F-Si Team 2015
Cannondale F29 Team 2014
Cannondale F29 Carbon 1 2013
PostPosted: Sat Oct 12, 2013 11:13 pm
yea pretty much i replaced with rival and then realizing the rear needed the same treatment, i just swapped shoes from my red group to the rear for the time being.
i'd trade shorty ultimate brake shoes for some road shoes
Instagramz
My Podcasts
PostPosted: Sun Oct 13, 2013 1:50 pm
Hmm. I am actually not sure the Avid shoes will fit my TRP carbon brakes. I will have to check.
There are no new unread posts for this topic. Caad 10 and Wide Rims
in Everything wheels
tomato89
7
694
Thu Dec 14, 2017 12:54 am
DamonRinard View the latest post
There are no new unread posts for this topic. Parlee Z5 SLi & wide rims
audiojan
11
1221
Tue Jun 06, 2017 9:21 pm
rst72 View the latest post
There are no new unread posts for this topic. Wide carbon tubular rims?
Eleven21
Wed Dec 20, 2017 9:55 pm
RyanH View the latest post
There are no new unread posts for this topic. Wide tubular tires on narrow rims
RyanH
24
1988
Thu Nov 02, 2017 11:23 am
Wingnut View the latest post
There are no new unread posts for this topic. Bontrager speed limit on wide rims
Attermann
Mon Aug 07, 2017 5:04 pm
FIJIGabe View the latest post
Users browsing this forum: ms6073 and 3 guests
cron
