It is currently Wed Jan 24, 2018 1:11 am
Post new topic  Reply to topic  [ 49 posts ]  Go to page 1 2 3 4 Next
 Post subject: Ritchey '12
PostPosted: Fri Jul 29, 2011 11:12 pm
Was just browsing bikeradar and saw these:
100g for 100mm despite featuring 7 bolts. More here: http://www.bikeradar.com/news/article/ritchey-bolster-component-lines-for-2012-31141
“I always find it amazing that a material can actually sell a product when it’s really the engineering that creates and dictates how well that material will behave or perform.” — Chuck Teixeira
RideWert.com
Wert Cycling on Facebook
 Post subject: Re: Ritchey '12
PostPosted: Fri Jul 29, 2011 11:18 pm
kinda defeats the point of having a face plate that comes of if you still cant fit the bars that way, looks to me like you would have to feed the bars through like the old 1bolt stems unless your running a bar with a flat section
PostPosted: Fri Jul 29, 2011 11:57 pm
Probably can take it off still unless you wrap it all the
way to 31.8 middle section of the bar.
PostPosted: Sat Jul 30, 2011 12:04 am
Spent many of my earlier years dealing with removing levers and tape to be able to thread the bars through - Jeezz what a backward step from Ritchey :shock: :shock:
Nooooo Thanks.
PostPosted: Sat Jul 30, 2011 12:29 am
Most bars will come off without removing levers... It will remove at the point where most bars taper.
charles@pezcyclingnews.com
PostPosted: Sat Jul 30, 2011 1:14 am
Thanks Pez - now that you mention it - with the larger center clamp sections (versus the older 26mm) it does make sense that it would work
PostPosted: Sat Jul 30, 2011 1:34 am
Indeed, this 260 stem wouldn't work with, say, Pro Vibe bars, that have a continuous section of 31.8mm from where the stem clamps until where it tapers off to about 24mm in the bend where the the levers clamp.
I'm sure it'll work with all Ritchey bars. Why otherwise would Ritchey bring such a thing out? Think whatever you think, I'm just the messenger and also happen to like Ritchey's design. That said, it's better illustrated by a picture, where you can see that 260º clamping of 31.8mm is more than 24mm so it gives enough space for the bars to pass through at the sections with the smaller diameter:
RideWert.com
PostPosted: Sat Jul 30, 2011 4:19 am
pro built a better mousetrap
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
PostPosted: Sat Jul 30, 2011 4:33 am
Better in what measure(s)?
PostPosted: Sat Jul 30, 2011 4:43 am
Another article explaining the design
http://www.singletrackworld.com/2011/07 ... -new-stem/
PostPosted: Sat Jul 30, 2011 6:36 am
From the article...
{USERNAME} wrote:
The Pro teams are currently using it in the Tour. The alloy stem is 3-4 times better than Ritchey’s previous stem in testing – and it’s 30% stiffer than Ritchey’s popular (and winning) 4Axis stem.
3-4 times better! :smartass:
PostPosted: Sat Jul 30, 2011 7:14 am
The pro vibe is worse in at least one way: you can't flip it so it's less versatile.
PostPosted: Sat Jul 30, 2011 11:02 am
Location: Lima, Peru and occasionally in the Washington DC area.
Don't let your thinking get in the way of marketing! It is 3-4 times better and has been scientfically proven! :wink:
PostPosted: Sat Jul 30, 2011 11:10 am
Administrator
Pete, absolutely. It goes to 11! :smartass:
RESIDENT GRUMPY OLD MAN.
PostPosted: Sat Jul 30, 2011 11:17 am
interesting to see 3 bolts at the back!
There are no new unread posts for this topic. Ritchey NeoClassic so close to perfect but not quite...
xcnick
30
2595
Mon Sep 04, 2017 7:42 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. Ritchey Road Logic as second bike..
[ Go to page: 1 2 3 4 ]
3Pio
45
3646
Thu Dec 21, 2017 7:49 am
3Pio View the latest post
Users browsing this forum: Baidu [Spider], Bing [Bot], bm0p700f, Bordcla, dricked, glam2deaf, JS300, sib, wheelbuilder and 25 guests
