It is currently Tue Jan 23, 2018 11:32 am
PostPosted: Thu Jun 30, 2011 6:41 pm
My commute/adventure bike (Salsa Vaya) is currently equipped with a Sugino XD2 triple (26/36/46 x 170). I can't remember the last time I used the granny ring, so I'm thinking of changing over to a compact/cross double to (1) save a little weight, and (2) gain some stiffness (the Sugino uses a square taper BB).
Campy's 10-speed Cyclocross crankset looks like it would fit my requirements, but real-world reviews are still hard to come by. It's also unclear as to whether Campy went with non-standard chainrings (110 with 112, etc).
Any feedback on the Campy cranks? Or is there another 36/46-ish double out there with silver arms and an external BB that I should consider?
GRAVELBIKE.COM - ride everything
PostPosted: Fri Jul 01, 2011 5:35 am
I use a compact campy record crank for cross. 34/50.. I can't remember the last time I needed the big ring. but I'm a puss..your results may vary.
PostPosted: Fri Jul 01, 2011 7:20 pm
Do the Campag compact cranks use standard 110 BCD rings?
PostPosted: Sun Jul 03, 2011 8:09 pm
No, they don't due to the bolt behind the crank arm, which is proprietary to Campagnolo, somewhat annoyingly. TA do compatible chainrings in cross sizes, i.e. 46 and 48 teeth, but they are expensive (circa £50 each).
PostPosted: Tue Jul 05, 2011 5:29 pm
Campy says 110 but it has the hidden bolt
WW Velocipedist Gargantuan
PostPosted: Tue Aug 16, 2011 4:43 am
That hidden bolt is a pain in the *ss I had to mill out a pair of rotor q rings to make them fit on campy compact cranks
PostPosted: Tue Aug 16, 2011 12:48 pm
To answer the original question, Campag did make alloy compacts with a conventional 110 bolt pattern all round and that used a square taper bottom bracket. The last year these were made was 2006 except Xenon which was 2007.
PostPosted: Wed Aug 24, 2011 2:44 am
OK, I've put some miles on the Campy cross cranks now. Overall I like them. The 46x36 certainly works and the bearings are much better sealed then the ultra torque. Shifting is on par with other Campy chainrings. I am not a fan of the new system of securing the crank. Durable and stiff but it requires a 14mm hex wrench and some of those "special" tools that Campy loves. A step backwards IMO but having the much better seals makes it much more viable as a cross crank. Hit a few rocks with the crank and it has survived fine.
There are no new unread posts for this topic. 2018 CAMPAG HO RD vs 2015 CAMPAG RD
wwnick
Wed Jul 19, 2017 9:11 am
wwnick View the latest post
There are no new unread posts for this topic. Tune Mag 170 hub 24H Campag 11s
dmoneysworks
Mon Jan 08, 2018 10:58 pm
dmoneysworks View the latest post
There are no new unread posts for this topic. Campag bora 35 clincher - how much?
in Everything wheels
twelve
Sun Jun 18, 2017 12:01 am
AJS914 View the latest post
There are no new unread posts for this topic. Tune TSR 22 - 11 speed Campag
Chilterncyclist
Wed Oct 18, 2017 7:59 am
Chilterncyclist View the latest post
There are no new unread posts for this topic. FS: Campag 11 kit - mechanical and EPS - new prices!!!
jonjones13
Tue Oct 17, 2017 3:42 pm
jonjones13 View the latest post
Users browsing this forum: No registered users and 5 guests
