It is currently Tue Nov 21, 2017 5:09 pm
Post new topic  Reply to topic  [ 6 posts ]
 Post subject: Time Slice carbon fork
PostPosted: Sat Dec 13, 2003 8:28 pm
I just pulled the fork off my '03 CAAD 7 and weighed it. I've always hated this fork for aesthetic reasons, and now I have a weight reason as well: 407 grams cut. I like straight blade forks, does anyone have any of those stiffness numbers on a alpha q sub 3 or those new Easton straight blade forks (claimed 350 grams, but they look cool) Thanks
 Post subject:
PostPosted: Sat Dec 13, 2003 8:53 pm
I've ridden one of the older EC90's (the ones with the "aerodynamic" brake gap, or whatever you want to call it). I'm 5'10" and 150-160 lbs. (depending on the season) and I've never had any problems with flexing. I've pushed it pretty hard too. They do look pretty sweet, well, depending on your ride, what kind of frame do you have?
 Post subject:
PostPosted: Sat Dec 13, 2003 9:15 pm
Just to let you know the '04 Slice SI all carbon weighs 312g uncut, and 410g, with starnut, bolt, topcap, and headset! I think it's the lightest fork setup you can get. The easton is a few greams lighter, 13g, but because the SI fork uses a starnut it saves more weight and makes a lighter set up.
 Post subject:
PostPosted: Thu Dec 18, 2003 1:49 pm
Hallo Dan,
i am not shure if this is what you are looking for, but, concerning the Easton EC 90 SL, I have some stiffness numbers for you (from a review in a german magazin): 4 Categories, all in Newton/mm: brake-87,7/jump(reverse power to brake, concerning comfort) 88,1/lateral-45,5/shaft-4.731. Very stiff in all directions. Not very comfortable, especially for light-weight-people. They tested the Easton EC90 SLX too, which is 35 gramm lighter but, especially lateral and shaft, less stiff. (33,8 and 3154)
PostPosted: Thu Dec 18, 2003 5:01 pm
Is that fork the same as in the CAAD4 from 2001? I got an CAAD4 from 2001 with an Time Slice carbon fork.
 Post subject:
PostPosted: Thu Dec 18, 2003 8:05 pm
I have the 2001 Caad 4 with the 1 1/8 Headset too. Mine has a carbonfork with aluminium steerer. This is much heavier than the Caad 7 Fork, it weighs about 560 gramm. But the Frame is pretty light (mine is 1305 gramm in size 56)
There are no new unread posts for this topic. 2012 Cannondale Slice 5 VS 2014 Stradalli Phantom II
Alpine318is
Tue Mar 14, 2017 7:43 am
jekyll man View the latest post
There are no new unread posts for this topic. Cannondale Super Slice Disc brake version
[ Go to page: 1 2 3 4 5 ]
alcatraz
61
3798
Thu Sep 14, 2017 9:51 pm
TobinHatesYou View the latest post
There are no new unread posts for this topic. Attachment(s) Weird discoloration on carbon fork
dtsftw
Sun Nov 12, 2017 4:07 am
dtsftw View the latest post
There are no new unread posts for this topic. Attachment(s) SystemSix carbon fork with starnut
martinko
Sun Oct 15, 2017 5:37 pm
martinko View the latest post
There are no new unread posts for this topic. Hints for 1" carbon road fork
sheberin
23
1566
Thu Jun 01, 2017 8:06 am
gonsales76 View the latest post
Users browsing this forum: ewwhite, karmaz, Shortsocks, wobbly, Yahoo [Bot] and 42 guests
