The Canyon love thread
carbonLORD
by carbonLORD
carbonLORD.com
Peter_E
by Peter_E
Frame, fork, headset and included liners were 1 390 grams. Bar/stem 322 grams and seat post 234 grams
iamraymond wrote:
Peter_E wrote:Got this Endurace CF SL disc frameset built up. Picture is not that great but happy with it (looks, weight, not ridden it yet). Sram Redgroup with new S-700 shifters, Fulcrum Quattro carbon wheels, 28mm Vittoria Corsa G etc.
Do you know what the weight was of the frameset, bars, seat post?
iamraymond
by iamraymond
Peter_E wrote:Frame, fork, headset and included liners were 1 390 grams. Bar/stem 322 grams and seat post 234 grams
Thanks for the info! It’s very helpful. I’m going back and forth between the Ultimate SL disc and the Endurace SL disc, and I’m leaning now more to the geometry of the Endurace.
Peter_E
by Peter_E
I did the same. In the end I felt that the Endurace in Small would be a little small (too low stack) but Medium too big (especially seat tube) so decided on the Endurace in S. I am 1.78 with longish legs so in between Canyons sizes.
Skickat från min iPhone med Tapatalk
rs84107
by rs84107
not necessarily a racing bike but one based on a racing bike... received this beauty yesterday but way to cold in this part of the world to try it out :P :P
The predecessor was also a canyon... but with 2,2 kg more....
mattr
by mattr
Anyone else bought a Lux recently and had issue with loose bolts in the suspension?
BelligerentBivalve
by BelligerentBivalve
No but god help you if you want help from canyon service. I've found them to be all smiles and promises before purchase but useless afterwards. Keen to hear if they help.
mattr
by mattr
No. Canyon themselves were fairly helpful once they realised that there was an issue. Took them a couple of weeks though.
Just wondered if anyone else had been affected.
robikka
by robikka
robikka wrote:so I received an answer from Cayon saying that the frame is asymetric and on every one it is the same as on mine. That this is the feature of the frame an it is the way how the frame was designed. So owners of latest canyon ultimate cf slx model what do you think do you see it the same way?
Canyon received my frame and now I am waiting for their reply (canyon has to check it), will let you know how it ended
duckit
by duckit
Hey guys
I am on the verge of pulling the trigger to order an Ultimate CF SLX 8.0 DI2 rim brake version.
However, i am torn between a size S or size M.
I did a bike fitting last year for a used Cervelo R5 which is a size 56 ( the frame was a hand-me-down ) and i was advised to use a 80mm stem but due to aesthetic purposes, i used a 100mm stem instead + not slammed. I do feel overstretched at times but still manageable.
I figured that the R5 is probably too big for me.
And as I compared both bikes' geometry;
Below are my findings, i might be wrong as i am really not good at reach / stack and stuffs so please correct me if i am going the wrong direction.
the R5's reach + recommended stem length 80 mm = 467 mm
the R5's reach + the 100 mm stem i used = 487 mm
the size M's Ultimate's reach + the integrated stem length 100mm that comes with it = 491 mm
the size S's Ultimate's reach + integrated stem length 90mm that comes with it = 475mm
Basic above, it would seems i will be even more stretched on the size M ultimate compared to the R5 with 100mm stem.
I've also punched in my numbers on the Canyon PPS and i was recommended a size M so i am pretty confused.
I am about 180-181cm tall with an inseam of 84cm
My saddle height at the moment is about 706mm from center off bb to center of saddle profile.
Let me know if i missed out anything.
Any input will be appreciated !
Thank you !
Ticlimax
by Ticlimax
duckit wrote:Hey guys
Thank you !
Reach without stack isn't as meaningful. The small will be better when it comes to reach, but maybe the bars will be to low. If the drop on the S (or the necessary spacers) suit you, go for it. A bikefitting is more reliable than Canyon's PPS.
rasmusic
by rasmusic
mattr wrote:
Tue Dec 12, 2017 1:00 pm
Got a warranty replacement frame recently and had to use loctite on most bolts after the first trip. Disappointing.
mattr
by mattr
Yeah, that's a similar experience to the one i had. Turns out they misprinted the torque specs on the pivot bolts. Instead of 12Nm and threadlock, they printed 3Nm. Even threadlock isn't going to save that.
All tightened and threadlocked now.
robertbb
by robertbb
Ticlimax wrote:
Fri Dec 15, 2017 6:37 pm
Thank you !
I have almost identical measurements to you, and I would say I am about medium flexibility. I went with an S and it's perfect.
It's ALL about the bike.
duckit
by duckit
robertbb wrote:
Fri Jan 05, 2018 4:38 am
Thank you !
Thats nice !
Did you remove the spacers or stock stack on the Size S
