It is currently Thu Nov 23, 2017 7:47 pm
Post new topic  Reply to topic  [ 14 posts ]
 Post subject: Bb30 crank to bb86?
PostPosted: Sun Feb 27, 2011 6:34 am
Is there any way to put a bb30 crank system (I have cannondale) into a bb86 frame type system??
Thank you.
Theforcetraining.com
 Post subject: Re: Bb30 crank to bb86?
PostPosted: Sun Feb 27, 2011 9:05 am
BB30 bearing OD is 42mm. BB86 shell ID is 41mm. So it won't fit.
PostPosted: Sun Feb 27, 2011 10:25 am
not possible at the moment
but know that Starnut on this forum are working on a 3 piece axle for hollowgram si (the alumnium one) and sisl that will make it possible, but i gues you loose some of the benefits of bb30 with it.
PostPosted: Sun Feb 27, 2011 5:21 pm
well the OD of the BB30 bearing is 42, but you just need a bearing with a ID of 30 and OD that is less than 41.
Quick search on Boca Bearings yields this.
http://www.bocabearings.com/bearing-inv ... RU-30x37x4
$60 a pop though.
You will still have to use a longer-than-true-bb30 spindle like a Zipp Vuma quad
PostPosted: Sun Feb 27, 2011 11:35 pm
Yeah, that's what I thought. Thank you guys. Hate getting some team bikes.
PostPosted: Mon Oct 15, 2012 3:13 pm
Sorry to drag up an older post but is there a solution to this problem?
I might be getting a team Storck Fenom next year (BB 86.5), but want to try and transfer my SiSl to it as I have the Quarq spider.
Is there any way to get this to work?
Thanks for any help.
PostPosted: Mon Oct 15, 2012 5:29 pm
No. Not really.
PostPosted: Mon Oct 15, 2012 7:32 pm
BB86 shell is 86.5mm wide whereas BB30 is designed for 68mm width shell - the crank spindle is too short. The only 30mm spindle crank that would physically fit is a Rotor, but then you still need to sort the bearings.
Just ride
PostPosted: Tue Oct 16, 2012 5:45 am
In short, you are trying to squeeze a short and thick rod into a long and narrow opening. Not gonna work. :D
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
www.falcobike.com
Facebook: falcobikeglobal
PostPosted: Tue Oct 16, 2012 10:53 pm
Also, take a look at how your hollowgram crank mounts on the Cannondale frame and you will notice the chainrings are pretty snug against the bottom bracket sheel - i.e. no offset. That means that even with a longer spindle you are simply shifting the chainrings further out/away from the optimal chainline.
In addition to the Rotor 3D+, there is also FSA's BB386 offerings for which I thought I read that SRM will be offering an SRM K-Force 386. To make the Rotor 3D+/BB386 cranks work with a BB86 frameset, Rotor UK has the Press fit 4130 BB86 converter specifically for use with BB86.
PostPosted: Wed Oct 17, 2012 1:40 am
Thanks very much for the replies guys.
First world problems eh? Upset because I can't transfer my power meter to my new team bike ha ha
PostPosted: Fri Jul 04, 2014 8:35 pm
Sorry to pull this old one up again folks.
If I have a Rotor 3d+ chainset, the above suggests I can get it work ok on a new Canyon Ultimate CF SLX (2014) with its press -fit 86,5. I'd that correct?
Thanks.
PostPosted: Fri Nov 07, 2014 1:35 pm
[quote="aarw"]Sorry to pull this old one up again folks.
Thanks.[/quote]
Seems to me that with Rotor's 4130 you can use any BB30 crankset and have it installed on a BB86 frame? I wonder though if there is any consequences such as increased bearing resistance or decreased longevity? Anyone running this that can provide some insight?
Thanks in advance.
PostPosted: Fri Nov 07, 2014 3:44 pm
Not any BB30 crankset, just those with enough spindle length (Rotor, Tune, Bor, FSA 386evo, BBright etc.)
No additional resistance there, also there is ceramic version 4130 as well :) Longevity is no different than most of BB30/PF30 bottom brackets, just make sure your don't over tighten your crankset (fine tune with preload ring).
There are no new unread posts for this topic. SRAM Etap crankset with BB30 compatible with Scott Addict SL (BB86)?
wootenlakeguy
Mon Feb 20, 2017 11:17 pm
grover View the latest post
There are no new unread posts for this topic. BB86 frame with 30 mm spindle crank
LouisN
11
524
Tue Nov 21, 2017 2:26 pm
ms6073 View the latest post
There are no new unread posts for this topic. Lightest 30mm crank (bb30 = ok) with removable spider
alcatraz
34
1930
Tue Sep 26, 2017 3:04 pm
madcow View the latest post
There are no new unread posts for this topic. BB30 circlips when fitting BB30-24mm Bottom Bracket
thepainandsuffering
Mon Oct 16, 2017 1:26 pm
hambini View the latest post
There are no new unread posts for this topic. THM Clavicula SE BB86 questions
KaneChang
Sat Nov 11, 2017 7:04 pm
KaneChang View the latest post
Users browsing this forum: -Robin-, Attermann, Baidu [Spider], cooper, Google [Bot], gzon and 35 guests
