What is the weight of the Cervelo R3 & R3SL, R3 2011 & R5
v70cat
by v70cat
Was wonder what the differences in frame weight of the 2010 R3 & R3SL vs 2011 R3 & R5?
livio livius
by livio livius
What seize?
v70cat
by v70cat
Does not really matter just as long they are all the same.
My size is 54.
thisisatest
by thisisatest
i weighed an r5 58cm, it was 960g with seatpost collar, cable guide, derailleur hanger.
i weighed an r3sl a while ago, it was the nude/black one, 56cm, 805g with seatpost collar, cable guide, derailleur hanger.
i can weigh more tomorrow (if i remember)
justkeepedaling
by justkeepedaling
The R5 you weighed is the heaviest I've heard of. Typically mid 800 grams for a 58 cm
Carbon_Cowboy
by Carbon_Cowboy
My 2010 R3SL was 898 grams (54)
phallenthoul
by phallenthoul
R5 56cm frame/fork/headset/seat clamp/3D crankset w/ q rings 2065g.
v70cat
by v70cat
thisisatest wrote:i weighed an r5 58cm, it was 960g with seatpost collar, cable guide, derailleur hanger.
Thanks for the information, I thought the R5 was supposed to be lighter?
em3
by em3
Again....the numbers you are reporting are not correct. A 56cm R3SL will not weigh 805gm with everything hanging on it (that is just too light), nor will a 58cm R5 weigh 960gm with everything hanging on it, not even with the headset bearings either.
Here are some real weights from frames I own, weighed completely bare (w/out der hanger, seatclamp, cable guide, H2O bolts, headset bearings):
2010 R3SL 56cm, 840gm
2011 R5 54cm, 825gm
EM3
Smithmi81
by Smithmi81
My 2011 r3 size 54 weighed 925g with everything bar BB and headset. Pictures in a previous post.
em3
by em3
...guys, this is weight weenies...frame weight should always be reported with nothing hanging/installed on the frame :)
EM3
thisisatest
by thisisatest
58cm r5 is 960g, as i described.
56cm r3sl 2010. this one is 850, the one i described earlier, as mentioned earlier, was an older one, much less paint, at 805g.
just for kicks, i weighed a 58cm s3. It weighed 1090, which seems about right, given that they are a bit heavier than the slc-sl and the 58cm slc-sl on the front of light-bikes.de right now weighed 1032g.
i always weigh frames with bb cable guides, rear derailleur hangers, and seatpost clamps. It makes sense to. The post clamps on these bikes are proprietary (except for the r3sl).
and i forgot the picture, but the 2011 r3 was 1010g. pretty close to the r5 weight.
-Greg
ps. sorry about photo quality. resized them for WW, went too far. shouldve cropped some junk out too.
thisisatest
by thisisatest
I got the 2011 r3 weight from a coworker. 990g, but without the seatpost collar. to keep the weights standardized, 20g collar=1010g,
spartan
by spartan
cervelo have gotten heavier with time. my 2006 r3(clamp,hanger,bbcable guide) weighs 875gm.
trek6x/specialized sl3/cannondale ss are all lighter in comparable sizes. :shock:
Current Rides:
2017 Giant TCR Advanced SL 0 DI2 9150
v70cat
by v70cat
I am confused, I thought the California was all about making the bike lighter, yet the 2011 R3 and R5 are heavier?
