It is currently Sun Jan 21, 2018 1:52 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page 1 2 Next
PostPosted: Mon Dec 08, 2003 2:57 pm
What's the best way to transport mega light bike frames when taking them with you on a training camp.
PostPosted: Mon Dec 08, 2003 3:15 pm
That depends on a couple of factors, like: are you using a plane, the train or a car, and if you use a car, how is the bike mounted (on roof - bad, disassembled in the trunk- worse, standing in an SUV - ok...)
other Factor: how much abuse can your frame take? i have a scandium tincan frame in the sub-1kg-range which has tubing so thin i can bulge it with my thumb, but OTOH Carbon fiber frames are less delicate, i hear.
I personally have a "heavy duty" winter/bad weather ride that i use on such occasions, like going to Mallorca by plane. If i had to take the Scott, i'd go for a bike suitcase-style thingy.
Martin
 Post subject:
PostPosted: Mon Dec 08, 2003 3:19 pm
Sorry should have made myself clearer, I'm talking about planes. I don't fancy taking a heavy training bike, I want to take my full on racing bike, frame pretty light at 1030gm so do not want to trash
 Post subject:
PostPosted: Mon Dec 08, 2003 5:34 pm
You can try to this link:
http://www.elite-it.com/jsp/c-Prodotti. ... 9&LANG=ENG
Ciao Zauri
 Post subject: hard case!
PostPosted: Mon Dec 08, 2003 7:00 pm
If you want your bike to not be damaged it must be in a hard case!
Putting your bike in a soft case, no matter how thick or whatever. It can and probably will get damaged.
With the new security stuff going on you don't want to put extra stuff in and around your bike in the case either. They will open it and perhaps go through the stuff. And if they can't get the stuff back in they will tape it shut. Imagine your nice case with tape holding it closed and some clothes or whatever hanging half way out. They have to open it because they won't fit through the x-ray machine.
 Post subject: Re: hard case!
PostPosted: Mon Dec 08, 2003 7:14 pm
Make sure, you dissambel the stem rear derailleur and handlebar. Even when you use a hard bike case, you need to do it.
 Post subject:
PostPosted: Mon Dec 08, 2003 8:34 pm
http://www.pinkbike.com/modules/news/?o ... ew&id=1530
PLAY DARTS! *WARNING* MUST HAVE A SENSE OF HUMOR TO PLAY!!!
 Post subject:
PostPosted: Mon Dec 08, 2003 8:50 pm
Most decent bike shops rent hard travel cases for a few bucks a day.
Definately the way to go. I have used one a few times, on planes (we know how gently those baggage fellas can be) on trains and dragged in and out of taxis and not even a scratch. Pack carefully and you will be fine.
 Post subject:
PostPosted: Mon Dec 08, 2003 9:16 pm
go to ya LBS & ask for one ov those cardboard boxes bikes are delivered in.... believe it or not they transport bikes all over the world that way :wink: :roll: 8) :shock:
My Place :-)
 Post subject:
PostPosted: Mon Dec 08, 2003 11:26 pm
thankyou smart arse BUT have you seen how they are packed, its an engineering marvel. Everything safely wrapped and padded, who has 4 hours to pack a bike when youre on your hols you should be drinking pina coladas with umbrellas etc. Get a hard case nuff said :)
 Post subject:
PostPosted: Mon Dec 08, 2003 11:49 pm
Pina Coladas? You Nancy 8)
Real men drink Guiness before trying it on with the Ladies when holidaying in Mallorca!
Ride lightly!
 Post subject:
PostPosted: Tue Dec 09, 2003 12:12 am
If I was only old enough to drink... legally that is. :wink:
 Post subject:
PostPosted: Tue Dec 09, 2003 5:49 am
my dad has a hard case & i would chose the cardboard box route everytime :roll:
My Place :-)
 Post subject: Cardboard Boxes
PostPosted: Tue Dec 09, 2003 6:31 am
Packinga bike in a cardboard box should take les then 30min, if your not used to it. With practise 10-15 min including wrapping.
The important thing is to get a box the right size- they are designed around the bike they come with- to the mm!
In a cardboard box I remove the pedals, rear deraillier, front wheel and seatpost. Make sure you have a spare axle to stop the forks from getting squashed. If you have to remove the stem get the cardboard spacer to stop the frame moving inside the box.
I like cardboard - takes less room at hotel, less weight (no excess bagage) and QANTAS has really god ones that you get from them and leave with them that are wider than the ones we get in the shop.
 Post subject:
PostPosted: Tue Dec 09, 2003 10:49 am
the sci-con bike cases are the best around.. I've got a cheaper one but should have shelled out a bit more for the Sci-con Dpends how often you go too..no point buying a decent bike case if it's a 1-off trip.. quite a few shops hire 'em out though..
Doozer :mrgreen:
Dance you cares away, worries for another day, dance your cares away, down at fragglerock.
 Post subject:
Users browsing this forum: mrtkcmz, Titusrider, wicz and 39 guests
cron
