I links pics. Regular and Mini. [Test report on page 3]
Frankie - B
Administrator
by Frankie - B
Regular ones complete
Minis' complete
Brake inner
Shift inner
nutty
by nutty
how well will it work with campy11?
Frankie - B
Administrator
by Frankie - B
Please conduct a :search: before asking questions. Searching and learning from the search makes you smarter. sitting down and asking the question makes you lazy
greasypete
by greasypete
Frankie - B wrote:Please conduct a :search: before asking questions. Searching and learning from the search makes you smarter. sitting down and asking the question makes you lazy
You couldn't just say yes? I don't understand how you typing out 3 sentences referring someone to search is easier than just typing yes.
Juanmoretime
Administrator
by Juanmoretime
Greasypete. While it seems easy ask a somewhat related question you will find your answer by searching and not taking up bandwidth will questions that have already been answered on the forum.
Thanks!
Juan
RESIDENT GRUMPY OLD MAN.
Hawkwood
by Hawkwood
The brake inners will be lighter with the extra nipples cuts off.
coloclimber
by coloclimber
greasypete- do you have any idea who the OP is?
Show some respect :evil:
-Deacon Doctor Colorado Slim
prendrefeu
by prendrefeu
Alright, everyone just chill out.
Y'all sound like a bunch of people getting cabin fever and not going outside because of the poor weather. :roll:
Get on your bikes, trainers, rollers, whatever and clear your minds. Please.
Rich_W
Location: On an Island 6 Miles at Sea. Move over Smithers, I'm drivin...
by Rich_W
bikewithnoname
by bikewithnoname
coming back on topic, are the mini i-links only available as shifter housings, or will they also work as brake housing? It's not clear from the links or the stuff I can find on the web?
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
Redddraggon
by Redddraggon
Aren't those cables rather heavy?
Juanmoretime
Administrator
by Juanmoretime
bikewithnoname wrote:coming back on topic, are the mini i-links only available as shifter housings, or will they also work as brake housing? It's not clear from the links or the stuff I can find on the web?
For now shift only.
nutty
by nutty
ah..it's not that I didn't use the search function before asking the question, i have tried to search alligator campagnolo and stuff, but i can't find anyone using alligator cables with campy11 shifters. That's why i posted the question. Because jagwire shift housing is 4mm, the same as alligator's one, and the campy11 housing is 4.1mm. And from what I read, jagwire doesn't really work well with campy11, I was thinking if using alligator, would it be the same results?
Perhaps my question was so direct and short, and it sounded I did not search for the answer before asking, so sorry about that.
BmanX
by BmanX
Any ideas when the brake versions will be available. I am running Nokon's now on all my bikes but have put in my order for the shifter set up but would like to keep the builds looking good with just one cable housing set up if possible.
Does anyone know the weight difference between half a meter of the I-Link Mini's VS. half a meter of Nokon's. It would be interesting to see the weight differences between the two or better yet between the standard I-Links, Mini's and Nokon's.
Reason I am asking is because I am only about 170g from being under 6000g with my SLC and trying to get my P2K down to around 15.25 - 15.5 lbs and these might help get me closer to my goals.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Frankie - B
Administrator
by Frankie - B
Here are the parts that were left over
Regular I links:
Mini I links
The cables are quite a hassle to install as opposed to the Nokons that came off the bike. For people interested to know: a nokon liner does not fit into the mini I links so you need to wait to use the minis with a brake inner cable. If you want to run them as brake cables you can always use a shift inner cable to bring you to a halt. (before screaming that that will not be possible try it first then post.) I do not know if the mini i links will stand up to that job though. they might split like the carbon nokons did when used for braking.
