MSC Koncept Carbon Di2 - 6965g/15.35lbs
krzysiekmz
by krzysiekmz
Hi,
my current bike. Thanks to Jason at FWB for all help. Preety famous frame - http://www.mbaction.com/ME2/dirmod.asp? ... 03F82D04D8" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false; has now found a new owner, thankfully weight obsessed :)
Specs:
Brake: (Front) – Formula R1 (black polished, carbon lever, carbon clamp) - 160.4g
Brake: (Rear) – Formula R1 (black polished, carbon lever, carbon clamp) – 167.8g
-Rotor: (Front) - Innolite Design 160mm – 46.8g
-Rotor: (Rear) - Innolite Design 140mm - 38g
-Rotor bolts - 10xTi + 2xalu – 11.6g
-Rear Adapter: (Adapter 140mm) + 2xalu m6x14 – 16.8g
Caliper bolts - 2xTi + 2xalu m6x16 – 10.3g
Cables - Nokon Carbon/Nokon/Powercordz - 39g
Cassette - Shimano Dura Ace/XTR/Soul Kozak tuned 11-27 - 157.5g // Shimano XTR M-970 11-32 Tuned – 204.4g
Chain - KMC X9 SL Gold (105 links) – 238.7g
Crankset - Shimano XTR FC-M970 (FRM Pro 42t, R2 26t, Leichtkraft Ceramic BB) – 700.4g
Derlr. (Front) - Campagnolo Record (Speen adapter,alu bolts, alu mandrel) – 87.2g
Derlr. (Rear) - Shimano XTR Shadow RD-M972 SGS ( alu bolts, carbon hanger) – 151.6g
Fork - DT Swiss XRC 100 Race Limited – 1188.4g
Frame – MSC Koncept Carbon M (DT Swiss XR damper, KCNC Radiant headset bearings*, Ti/aluminium bolts, derr. Hanger, bikeshield protective foil) – 1573.9g
Grips – Extralite Ultragrips (Cut) – 9.3g
Handlebar - AX-Lightness Poseidon (Bar-end use) – 81.9g
Pedals - Crank Brothers Egg Beaters 3Ti (Ti springs, alu. nuts, plastic sleeves) – 157.7g
Seat – AX-Lightness Phoenix – 57.6g
Seatpost - Lire Carbon 31.6x330mm – 118.5g
Seatpost Clamp - Lire Carbon – 8.1g
Shifters - Microshift (Nobu) Tuned – 81.7g
Skewers - Tune DC 16/17 – 35.4g
Stem - Syntace F99 90mm (Ti bolts) – 90.6g
Headset – KCNC Radiant (Tune BuBu Cap) – 10.2g*
Top-cap - Soul Kozak Light-bike edition (Cut, hollow) – 3.7g
Expander – Extralite Ultrastar (polished) – 8.7g
Tire (Front) - Schwalbe Rocket Ron 2.1 – 408g
Tire (Rear) - Schwalbe Rocket Ron 2.1 – 416g
Tubes – CaffeLatex, valves (tuned with alu. nuts) – 108.3g
Wheel Front:
-Hub - Tune Princess 32h – 105.8g
-Rim - No-Tubes ZTR Alpine 32h – 325.2g
-Spokes - DT Swiss Aerolite – 140.2g
-Nipples – Dt alu. – 9g
-Rim Tape - 5g
Wheel Rear:
-Hub - Tune Prince 32h – 190.8g
-Rim - No-Tubes ZTR Alpine 32h – 326.5g
-Spokes - DT Swiss Aerolite - 139g
-Nipples - Dt - 9g
-Rim Tape - 5g
-(Misc.) – Bar plugs, zip-ties, schmolke paste – 10g
Total: 7451g / 16.42lbs
Weighted on a hanging scale: 7460g / 16.45lbs
Still few upgrades coming along with some tuned parts.
Orbea Oiz - xxxx
MSC Koncept Carbon Di2 - 6955g
Leichtkraft Team Carbon - 6868g.
Sonny
by Sonny
WOW~~~ Crazy light and NICE bike !!!!! :beerchug:
16.72lbs for a FULL suspension bike !! Next step to lower the weight to under 16lbs ???
greenbike
by greenbike
Well done! that is so freakin light and looks great too
krzysiekmz
by krzysiekmz
Yes, will try to go under 16lbs but how not to loose durability :noidea: What would you swap? Thanks for the compliments.
Chris.
Orbea Oiz - xxxx
elasto
by elasto
Nice job! If you want to go lighter maybe some Clavicula cranks and carbon rims like Innolite XCC250. Not sure how they run tubeless though.
konakula
by konakula
Thats really impressive build list, gives me something to aim for maybe with my Koncept
currently around 23lb so some way togo!
krzysiekmz
by krzysiekmz
Get your Koncept out here so we could suggest something :thumbup: Mine still awaits the Ax-Lightness crankset and I'm planning to upgrade the wheels, besides few minor things to be changed :D
Chris.
Orbea Oiz - xxxx
krzysiekmz
by krzysiekmz
Bike is now 7535g with a change of cassette and hardware :D Aiming for 74xx soon.
Chris.
Orbea Oiz - xxxx
krzysiekmz
by krzysiekmz
7451g now or 16.43lbs :)
Any idea how to get under 16lbs...?
Chris.
Orbea Oiz - xxxx
Sonny
by Sonny
Update part list ??
King Weel
by King Weel
Hi, how do you rate the Innolite rotors? Can you compare them with the performance of Scrub rotors? And where did you get the Lire Carbon parts?
Specialized S-Works Allez (the shiny one :) )
Turner Czar
krzysiekmz
by krzysiekmz
Partlist updated in 1st. post. Below a list of upgrades as well.
I have not tried Scrub rotors. Innolite are fine when used with correct pads. Not a raceday rotor btw; as you would like more performance out of it then. I'm not 100% satisfied that's why soon(hopefully) I'll upgrade to Titanium rotors of very similar weight.
Lire Carbon parts are made by my friend. He does seatposts, bottlecages, barplugs, bar-ends, seatclamps etc. Contact info on PM if interested.
Shimano Dura Ace 11-27 cassette with some xtr cogs + Soul Kozak aluminium 11,12 cog -46.9g
Ti frame bolt changed to aluminium - 2.4g
RS Monarch>DT Swiss XR - 84.5g
Not mounted yet. Waiting on frame bushings.
Orbea Oiz - xxxx
tonytourist
by tonytourist
That's a serious machine :twisted:
krzysiekmz
by krzysiekmz
Crankset upgrade will have to wait until spring. In the meantime I might consider lighter wheelset. So far small pieces to shave a bit of weight.
Orbea Oiz - xxxx
krzysiekmz
by krzysiekmz
The bike got a drivetrain upgrade. Di2 rear derr. and a satelite shifter with all internal battery and cables.
Orbea Oiz - xxxx
