It is currently Sun Dec 17, 2017 3:41 am
Post new topic  Reply to topic  [ 5871 posts ]  Go to page Previous 1236 237 238 239 240392 Next
PostPosted: Mon Dec 10, 2012 7:46 am
Anyone know what color veloplugs fit the BHS 472w (Kinlin XC279) rim? Or if they'll fit...
Thanks.
PostPosted: Mon Dec 10, 2012 8:26 pm
Just ask Brandon when you order, he knows and/or can test before he ships it out.
PostPosted: Wed Dec 12, 2012 6:01 pm
i'm looking to build my first pair of custom wheels, just need some views on which hubs and lace patterns to use. I'm 6"2, around 200lbs
Hubs
Tune or alchemy or any recommendations? is 24F 28R enough?
Rims
H+Son Archetype or Kinlin (if so which 1) or velocity a23
Lacing patterns
Was thinking Front(radial) Rear (3x)
would it be stiff enough for everyday riding?
PostPosted: Wed Dec 12, 2012 7:31 pm
Stiffness depends mostly on three things- rim stiffness, hub flange spacing, number and cross section of spokes. Lacing pattern has some effect, especially if you're doing one that puts the heads all on the inside or outside of the flange.
Stiff enough depends on the rider. Not just rider weight but also riding style. For example I'm 145 lbs and regularly killed rear wheels until I started building them myself and learning what makes a stiff wheel. I do a lot of climbing, climb out of the saddle a lot, and rock the bike more than most when I do so. Steep climbs in low gears stresses the rear wheel as does my riding style.
Someone much heavier but who rides differently could stress his rear wheels less than I do.
PostPosted: Wed Dec 12, 2012 7:44 pm
I have never built with Tune or alchemy hubs but the flange spaing on both hubs are as good as you are going to get.
What Eric says is very true. I amkind to wheels but a mate of mine is not he is a wheel destroyer but we are the same weight. The differene he is a power station.
As for rims.
The Kinlin XR-270 or 300 are both quite light at 445 and 465g repectively but due to the low price you can expect the quality of the braking surface and the spoke drilling to be not as good as the Veloity or H+ plus sons rims. Do not take that as the Kinlins are bad in fact the quality of the extrusion and join is very good as even tensions result. Both these rims in 24F and 28R would give you sufficient stiffness. Use laser or CX-ray spokes front and rear. The rear DS could be race spokes if stiffness is a concern due to you being a power house.
The A23 rim I would go for 28F and 32R for your weight for everyday riding. For event use only then 24F and 28R might be suitable but I still would not do it. I would build with Lasers fornt and rear NDS and Race spokes DS. Of course the rim is 23mm wide so you get the benefits of that.
The Archetype is a stiffer rim so 24F and 28R should be fine . There is nothing wrong with radial front (I prefer the look of 2x personally) and why not try 2x DS and 3x NDS on the rear. It gives slightly better tension balance (very slightly). I have normally used 2x both sides for 28H wheels but I have tried 3x. I find it difficult to tell the difference in the wheels when riding them. Zen Cyclery is going to say build the rear 3x and there is nothing wrong with that. I would build with lasers front and rear NDS and Race spokes DS. The archetype is 23mm wide so you get the benefits of that.
I would use any of the above rims with out hesistation but for 24F and 28R the Kinlin XR-300 would give the stiffest build laterally (even with laser or CX-ray spokes all round). The Archetypes would give the lightest with the same spoke count but not as stiff.
So it depends on howkind you are to wheels which will depend on how you ride and how powerful you are.
www.thecycleclinic.co.uk
PostPosted: Wed Dec 12, 2012 8:51 pm
Contrary to what you said, I find the braking surface on kinlin rims superb. I agree with all your other points though.
Bike: Felt FC
Strava
PostPosted: Thu Dec 13, 2012 2:55 am
Thanks guys for the reply, i guess I'm leaning towards the Archetype for now, i like the wider rim and look of it :P and of course it being the lighter wheelset hopefully.
But i would love to find out more on the two hubset that i mention and if which of them would be a better choice.
I'm not so sure if I can consider myself as a powerhouse as i do not have a powermeter to see how much watts I'm putting out.
PostPosted: Thu Dec 13, 2012 5:06 am
They use RED.
Thanks.
http://www.bikehubstore.com
PostPosted: Thu Dec 13, 2012 8:07 pm
Hello
need help
wich tool is the best for removing debris from drilling rim holes?
debris are marked red circles (they are flattened becouse rim was built and nipple has tension)
sorry i dont know correct expression - hope you understand
http://kavitec.blogspot.com/
My NEED FOR SPEED ride:)
https://www.youtube.com/watch?v=8hhlPRud7oM
PostPosted: Thu Dec 13, 2012 9:33 pm
what you need is the right size of something like this:
http://comptools.co.uk/store/trend-snap ... 44537.html
A drill slightly bigger than the hole to countersink will also work
PostPosted: Thu Dec 13, 2012 11:04 pm
this
http://ergottwheels.smugmug.com/Sports/ ... M&lb=1&s=A
PostPosted: Sat Dec 15, 2012 7:21 am
Awesome thread ! I am trying to build up a 1500 grams aluminum clincher wheels. What rims, hubs, and spokes and nipples would anyone recommend. I am 130 to 135 pounds and on budget . :D
PostPosted: Sat Dec 15, 2012 12:30 pm
Well you an have lighter but for 1500g
How about Velocity Aero head 24F/28R with Novatec A291SB/F482SB hubs with Sapim laser spokes as alloy nipples (so long as you are not near salt) ~1435g
Kinlin XR-200's with the same hubs and spokes/nipples would be ~1340g with A291SB-SL/F482SB-SL hubs then weight would be ~1305g. If a 20 spoke front wheel is use then take another 20g of. But for the sake of 20g I'm not sure it is worth it.
PostPosted: Mon Dec 17, 2012 11:12 pm
how do i calculate what length spokes i need?
i'm not going to build them myself, but i have a good idea of rims/hubs
i want to use a 90mm hong fu rim with alchemy orc hub for rear, and hong fu 22mm rim with alchemy ELF hub for front
probably 24/28 hole (i'll be 150lbs race weight)
PostPosted: Tue Dec 18, 2012 12:21 am
spoc calc downloaded from sheldon brown site. Follow his directions on measuring hubs and rims. .
There are no new unread posts for this topic. Thread together BB for BBRight
morganb
Wed Sep 27, 2017 6:09 pm
stevod View the latest post
There are no new unread posts for this topic. Attachment(s) Another Pedal Thread..
[ Go to page: 14 5 6 7 8 ]
3Pio
105
13253
Tue Aug 01, 2017 2:25 am
C36 View the latest post
There are no new unread posts for this topic. Another Shoe Thread
in MTB
LeDuke
Sun Aug 20, 2017 1:30 am
simoncx View the latest post
There are no new unread posts for this topic. Campagnolo missing thread
ncornelisse
Sat Sep 30, 2017 4:16 pm
Valbrona View the latest post
There are no new unread posts for this topic. Ultra Torque L/H thread
beanbiken
16
782
Tue Jul 25, 2017 3:24 pm
AJS914 View the latest post
Users browsing this forum: No registered users and 1 guest
