It is currently Fri Dec 15, 2017 9:10 pm
Post new topic  Reply to topic  [ 198 posts ]  Go to page Previous 1 2 3 4 5 614 Next
 Post subject:
PostPosted: Sat Sep 10, 2005 8:28 pm
are giant carbon racing components are compatible?
 Post subject:
 Post subject:
PostPosted: Sat Sep 24, 2005 9:48 pm
Does the tune speed needle fit with the stock alu seatpost from scott? ( the OS one with 34,9 mm )
 Post subject:
PostPosted: Sun Sep 25, 2005 6:14 pm
This will definetly not work.
 Post subject:
PostPosted: Sun Sep 25, 2005 7:53 pm
Oh? Why not?:(
 Post subject:
PostPosted: Mon Sep 26, 2005 8:31 am
Is the speedneedle compatable with either:
Deda Supercarbon RS
Deda black stick?
thanks...
"Ride it like you've just stolen it!"
 Post subject:
PostPosted: Mon Sep 26, 2005 11:32 pm
The Scott seatpost can't handle the bigger rails. It works with a hinge or how do you call it. Anyway you just crush the rails when tightening the bolt.
 Post subject:
PostPosted: Thu Oct 06, 2005 4:22 pm
Ummmm, my Speedneedle is definitely not compatible with Extralite the Post UL. It fits, but the rails were a bit offcenter to the grooves on the post. The rails were kind of not straight so that's why it would not fit ok.
I ground the bottom half-pipe of the post and now it fits alright, but definitely not a workable solution out of the box.
 Post subject:
PostPosted: Fri Oct 07, 2005 8:28 am
That's strange - my speedneedle seat works very fine with my extralite seatpost!
My blog
 Post subject:
PostPosted: Fri Oct 07, 2005 3:26 pm
The problem with mine was that one of the Speedneedle rails was not perfectly centered along its length. Poor quality control on Tune's behalf.
It was made with a slight bend along it's length, which messed up where it got caught in the grip by the post. If the rail was made straight, there would have been no problems fitting it.
 Post subject:
PostPosted: Mon Oct 10, 2005 5:03 pm
Tippster wrote:
cadence90 wrote:
Seatposts compatible with TUNE Speedneedle:
- Tune Starkes Stück
- Extralite (all posts)
- Easton EC 70
- Thomson seatpost (a friend of mine runs this combination)
- USE Alien with OS head
- Control Tech RP Carbon Comp
Seatposts NOT compatible with TUNE Speedneedle:
- USE Alien
- Easton CT2
- M2Racer
- Race Face XY
USE Alien with OS head only works if you file away between 1.5mm and 2mm off the clamp head. I have done this successfully.
May I know how to check if Alien with OS head or not? e.g. Is this one with OS head? http://www.performancebike.com/shop/pro ... y_ID=5261# Thanks.
 Post subject:
PostPosted: Wed Oct 12, 2005 11:22 am
Deda Supercarbon RS
Deda black stick?
thanks...
No problem with Deda black Stick. This is my set up on my road bike.
my Litespeed Archon custom :
http://img524.imageshack.us/img524/5777/p1020813zg4a443pn2.th.jpg
 Post subject:
PostPosted: Wed Oct 12, 2005 11:37 am
I think the only way to get the OS head is to order it direct from USE.
It wont be a standard issue fitment to any of the seatposts.
 Post subject: SpeedNeedle and Colnago
PostPosted: Thu Oct 13, 2005 8:33 pm
Does anyone knows if the SpeedNeddle will work with my Colnago C50 28mm post? Thanks, IDB
 Post subject:
PostPosted: Thu Oct 20, 2005 10:28 am
Rickyfirst wrote:
Deda Supercarbon RS
Deda black stick?
thanks...
thank you!!!
 Post subject:
 Post subject:
PostPosted: Thu Oct 20, 2005 10:30 am
May I know how to check if Alien with OS head or not? e.g. Is this one with OS head? http://www.performancebike.com/shop/pro ... y_ID=5261# Thanks.[/quote]
All USe posts come with a standard clamp head able to take rails of 7mm x 7mm. You have to order the OS head seperately. The OS head is made to take rails of 8mm x 8mm.
The TSN has oval rails 8mm x 10mm (from memory). Thats why even an OS clamp head still needs modifying to allow taller rails to fit.
There are no new unread posts for this topic. Re-covering tune speedneedle
Martin.F
Thu Mar 02, 2017 2:03 am
Fixie82 View the latest post
There are no new unread posts for this topic. Speedneedle for CX or Alternatives for Speedneedle.
MasterOMayhem
Sat Jul 29, 2017 6:09 pm
Tomstr View the latest post
There are no new unread posts for this topic. Speedneedle 20Twenty
whydobearsxplod
Tue Oct 10, 2017 2:01 pm
whydobearsxplod View the latest post
There are no new unread posts for this topic. BIG list of parts (again!)
jonjones13
Wed Oct 25, 2017 8:33 pm
jonjones13 View the latest post
There are no new unread posts for this topic. New build - part list resource?
mvcap
Fri Aug 11, 2017 2:45 am
53x12 View the latest post
Users browsing this forum: No registered users and 5 guests
