Post new topic Reply to topic  [ 39 posts ]
Go to page 1, 2, 3  Next
 Post subject: Stem for 1 1/4 "
PostPosted: Sun Nov 01, 2009 7:04 pm
Anyone know some, who makes that kind of stem?
I got my Canyon SLX today and got a Ritchey WCS stem for it. I would like to have a 3T but I don´t think its possible.
Is that right?
N/A CYCLES
Trek Madone SL 2007 Clearcoat
 Post subject: Re: Stem for 1 1/4 "
PostPosted: Sun Nov 01, 2009 7:23 pm
I think the only aftermarket stem available for 1 1/4" steerer tubes is Syntace F119 http://www.syntace.com/index.cfm?pid=3&pk=964
Syntace F119 fit 1 1/4" steerer tubes as standard and if yoiu want to use it with a regular 1 1/8" steerer, then you have to use the included alu insert:
Quote:
Syntace F119 Steerer Ø
28.6 mm (1 1/8") with alu insert, 1 1/4" without insert
You should also be able to buy another lenght Ritchey OEM stem through Canyon if you need another lenght. This stem fits their propitary 1 1/4" steerer tube, and maybe they have some FSA OS-115 OEM 1 1/4" stems in stock too, they used to sell bikes with this stem for a short while and have also sold bikes with the Syntace F119 stem.
You can only buy the Ritchey 1 1/4" stem through Canyon.
I'm not aware of anyone but Canyon who use 1 1/4" steerer tubes/stems, and that's why in general you can't buy aftermarket stems for this size except for Syntace F119.
PostPosted: Sun Nov 01, 2009 7:31 pm
I suggest reading this thread, but am not sure how up to date or accurate the information is viewtopic.php?f=3&t=42524
PostPosted: Sun Nov 01, 2009 8:37 pm
Thanks alot. I´m thinking about some custom paint so it fits better in colors. The bike will be in the gallery sonest in septemper next year. :?
N/A CYCLES
PostPosted: Mon Nov 02, 2009 5:02 pm
The Specialized pro-set stems are 1-1/4, but use adjustable shims down to 1-1/8". The shim system allows you to dial in the angle, but it will work as 1-1/4 without the shim. They pop up all the time on e-bay. I've used the comp-set version and the pro-set. Both are really stiff, but the comp is a boat anchor. Also available from specialized.
PostPosted: Mon Nov 02, 2009 6:29 pm
Nice find. The Specialized stems are available in both 12°, 17° and 24° angles without the adjustable shims.
Pro-Set and S-WORKS Pro-Set are available in 12° and 17° from 75 to 140 mm.
Comp-Set is available in 12° and 24° from 75 to 130 mm.
Many people have been looking for more drop for Canyon bikes than the 6° of the stock Ritchey stem.
Specialized stems: http://www.specialized.com/us/en/bc/SBCEqSection.jsp?sid=EquipComponentsRoadStems&eid=5135&menuItemId=9305
You can buy them directly from Specialized's US website.
S-WORKS Pro-Set Black/Carbon
S-WORKS Pro-Set White
Pro-Set Matte Black
Comp-Set Matte Black/Silver
PostPosted: Mon Nov 02, 2009 8:34 pm
Thanks for adding in the details, 2-Wheels. I'm really pleased with my pro-set. Stiff. Reasonable weight (160, but I'm not clear if that includes the shim, so possibly lighter for the 1-1/4 application). S-works will drop about 10 grams. Also, if you watch E-bay long enough, you can find a white one, as I did! The white only comes stock on a couple models and is not available through the website. But its hot and worth the wait.. if you're into the white stem thing.
PostPosted: Sat Nov 14, 2009 5:04 pm
Is that right?
PostPosted: Sun Nov 15, 2009 5:41 pm
The Syntace F119 stem is also 1"1/4 (with shim to 1"1/8)
Reasonably light (approximately 135grams), beautiful and strong
I Will make the leap
PostPosted: Sun Nov 15, 2009 10:49 pm
@ Stockie
Please read the topic before posting. Syntace F119 was already mentioned in first reply to this topic :roll:
PostPosted: Sun Nov 15, 2009 10:55 pm
2 wheels wrote:
@ Stockie
Oops, i didn't see it, was too quick. I read the part of the Ritchey stem though...
PostPosted: Mon Nov 16, 2009 5:04 am
If you prefer a white stem, you can also get a custom white Syntace F119 stem through Cube Bikes: http://www.cube-bikes.de/xist4c/web/acc ... 36541_.htm
Looks like Cube doesn't sell the 135mm length.
30424, Stem F119 Cube, white (90mm (124gr), 100mm (132gr), 110mm (139gr), 120mm (142gr))
PostPosted: Tue Nov 17, 2009 4:46 am
I just recently ordered a 110m Ritchey WCS stem direct through Canyon.
My Ultimate AL framset came with a 90m which doesn't work for me. I initially actually went and bought a 3T arx as a replacement, not realising it was a different spec. :noidea:
PostPosted: Tue Nov 17, 2009 1:36 pm
How much do they charge for that stem?
A light bike does replace good fitness.
PostPosted: Tue Nov 17, 2009 2:50 pm
I too ordered a 110mm WCS Ritchey stem directly through Canyon. I think it was something around 85euros at the time... a true ripp off!
Great news about that specialized stem being compatible. I think I might order a -17 for my canyon for next season. Shame that it comes at such a hefty weight penalty.
Canyon Ultimate SLX 2013 + DA9070 + Red Quarq + Corima Aero+ MCC (Ordered! 6.0kg)
Canyon AeroRoad + DA9000 + Lightning Power2Max + MCU's (6.5kg)
Cervelo P4 + G3 Powertap (7.78kg)
Cervelo SLC + SRAM Red 2013 + Red Quarq (6.8kg)
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: 573, gospastic, martroy, project3 and 61 guests
There are no new unread posts for this topic. Which stem?
BeeBee30
Fri Jun 01, 2012 7:52 am
SWijland View the latest post
There are no new unread posts for this topic. HED GTO Stem/Bar
micropox
Sun Jul 22, 2012 9:39 am
micropox View the latest post
There are no new unread posts for this topic. look 695 c-stem
triabas
Mon May 20, 2013 8:23 am
triabas View the latest post
There are no new unread posts for this topic. What bars / stem?
mrfish
9
636
Tue Oct 30, 2012 3:12 pm
project3 View the latest post
There are no new unread posts for this topic. Re-painting stem
Bregne
7
658
Wed Mar 27, 2013 8:00 pm
jedijeck View the latest post
It is currently Wed May 22, 2013 12:33 pm
