lightest valve extenders
WideAMG
by WideAMG
anyone research who makes the lightest valve extenders?
many sell them, zipp, bontrager, tufo, vittoria...
i weighed mine stainless ones tonight (bontrager i think) and they are 5g each.
are some available in aluminum or plastic?
riding Pinarellos with Super Record since 84
2009 SR Pino
QC is a management function, NOT country of origin
53x12
by 53x12
Tufo 40mm valve extenders are 2g each, 4g/pair. Scale verified.
Griswald4x4
by Griswald4x4
I don't know particulars but I know that kcnc makes extenders. They're likely to be the to be the top of the heap.
Superflies!
ritcheykestrel
by ritcheykestrel
I made a couple of carbon ones. They don't even register on my gram scale!
Ritchey BreakAway | Ritchey Swiss Cross | Kestrel 500EMS | Kestrel 200EMS | Kestrel CSX | Moots YBB Air | GT Edge TI | Colnago Track | Cervelo P2 | Time Equipe | Time Equipe Tri | Mondonico Anniversario | Many MANY others!!
vmajor
Shop Owner / Manufacturer
by vmajor
Well, there is the removable type...you screw it over the top of the , pump up the tire, unscrew it and put it in your jersey or tool pack.
They are not perfect, but they work.
V.
WideAMG
by WideAMG
53x12 wrote:Tufo 40mm valve extenders are 2g each, 4g/pair. Scale verified.
52x12 that's great, a winning reply in record time.
i will check these out.
2009 SR Pino
WideAMG
by WideAMG
ritcheykestrel wrote:I made a couple of carbon ones. They don't even register on my gram scale!
richey that is cruel. not funny man.
you'd better elaborate or i will stalk you :twisted:
2009 SR Pino
xcfisher
by xcfisher
Problem solvers are the lightest I have seen. The 33mm ones are less than 1g each!
http://www.bikeman.com/PU4500.html
11' Flash Ultimate, 1x10 - 15.7
11' SuperX Single Speed - 13.0
12' SuperX Geared - 15.3
12' Scalpel Ultimate, Wireless SRM - 18.3
53x12
by 53x12
No worries. In the US can find them for $5-9 per extender. Not bad at all.
53x12
by 53x12
xcfisher wrote:Problem solvers are the lightest I have seen. The 33mm ones are less than 1g each!
Nice, I will have to consider those for my next build.
ritcheykestrel
by ritcheykestrel
I bought carbon tubing from a US maker called Dragon Plate. www.dragonplate.com. They make many different types of tubing and carbon in general. I machined it down on the one end to hold the pump head on and the other I just threaded with a die. It works fine if you do it slow. What is nice is that the tubing comes in long lengths and you can cut it to what you need. They end up casting you about 12.00usd total for both. I have tried to get some pics put up here, but it always says they are too big. Sorry. Hope that helps.
