It is currently Fri Dec 15, 2017 11:31 am
Post new topic  Reply to topic  [ 56 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Fri Jul 17, 2009 1:44 pm
coloclimber wrote:
I didnt know the nova's flare.
It is so subtle that it is barely noticeable when they are on the bike.
PostPosted: Fri Jul 17, 2009 3:18 pm
it's very noticeable with sram levers i find
their levers are already on a bit of an angle, and when that's combined with a flare out, i find it very noticeable and uncomfortable, even if it is slight
just personal preference, with the way i position my levers, i find it noticeable and not pleasant
PostPosted: Fri Jul 17, 2009 5:06 pm
I am running Ergosum Team bars on my two cross bikes and getting Ergonova Pros for my single speed cross bikes. On the road it's just a matter of what I'm intending for the bike as to what bars I choose - if longer days or rougher roads, the Ergonova, if I want something lighter I get the Ergosum. They are both excellent bars, and I have no problem with the flat top and flair of the 'nova and then switching back to the 'sum when I want to...
___________________________________________________
"Organization is for the simple-minded, the Genius controls the chaos." - Jens
PostPosted: Fri Jul 17, 2009 9:15 pm
I got rid of the FSA WPC because there was such a drastic flare from hoods to drops. I don't find it noticeable with the Ergonova. I guess there's some, but it's negligible compared to the FSA. Here's a quick photo...
"Deserve's got nothing to do with it." William Munny
PostPosted: Sat Jul 18, 2009 4:47 pm
I am currently using the Easton EC90 Equipe handlebars. Do you guys think I would see any advantage changing to the 3T Ergosum or the Ergonova? My Easton's come in right at 205g, so I probably won't see much savings for weight unless I went with the LTD. Would I gain any stiffness? I haven't had any issues with the Easton's yet.
PostPosted: Wed Aug 05, 2009 12:09 am
I got both the Ergosums and Ergonovas yesterday. Which one shall I try first?
PostPosted: Wed Aug 05, 2009 3:36 am
If I were replacing my bars, I would definitely go with the Ergonova. I love a flat top (especially on a long climb). And I like the shorter (compared to what I am running now) drop of the Ergonova.
"I can't understand why people are frightened by new ideas. I'm frightened of old ones." -- John Cage
http://weightweenies.starbike.com/phpBB ... 928#126928
PostPosted: Wed Aug 05, 2009 4:16 am
i just bought a set of Ergonovas and am really happy with them... go the Ergonovas...
PostPosted: Wed Aug 05, 2009 4:29 am
I tried the ergosums first. Just went for a quick spin and I really like the initial bend from the tops, I can now grab the brakes while in the drops comfortably. The downside is I wish the drops went a little longer so I have more area for my hands. I'll try to ergonovas tomorrow.
I ripped my hoods during the install, now I have to procure some new ones :(
PostPosted: Thu Aug 06, 2009 1:08 am
you need to be careful when switching between the ergonova and ergosum bars on the same bike, with the same running gear.
i dont know why this hasnt been mentioned already, but the ergosum bars are a LONG reach, shallow drop bar. The ergonova bars have a SHORTER reach - i cant remember what the difference is off the top of my head, but I have the info at work - im pretty sure its over 10mm.
I use the ergosum bars as these are the longest reach shallow drop bars I can find.
If you want to use both bars to see which works, you need to take into account the reach.
Cheers
PostPosted: Thu Aug 06, 2009 1:54 am
Cheers
The reach is 89 for sum vs 77 for nova.
PostPosted: Thu Aug 06, 2009 3:21 am
How does the Ergosum compare to the FSA New Ergo (not the shallow)? I have been using them recently, and like them alot.
PostPosted: Thu Aug 06, 2009 9:08 am
boysa wrote:
I bought the Ergosum to replace the FSA WingPro Compact I had, and sent it back for the Ergonova. The shapes are similar, but the Ergonova has a flat section across the top of the bar and if I'm correct, it has even less drop and reach. I've been real happy with Ergonova. I think there was just a thread about this...
Do the FSA Compact bars have a longer flat area at the end of the drops? I'm struggling with the area on the Ergonovas. I'm so used to newton shallows nice flat area in the drops.
PostPosted: Thu Aug 06, 2009 4:28 pm
You should take photo's of both set up's.. please.
PostPosted: Thu Aug 06, 2009 4:37 pm
@boysa,
Thanks for sharing the photo showign the Ergonova flare. Do you happen to have a side view that you could post? I'm curious to see how the transition to the campy 11 levers looks with that bar.
Thanks
There are no new unread posts for this topic. Ergonova discontinued?
Zakalwe
15
3487
Sun Mar 12, 2017 5:12 pm
spliid View the latest post
There are no new unread posts for this topic. 3T Ergonova/Ernova
Geordiepaul
Wed Sep 27, 2017 7:52 pm
corky View the latest post
Users browsing this forum: 2old4this, benzebub, Digger90, Jaroslaw, stang1, stevec1975, torinb and 45 guests
