It is currently Mon Dec 18, 2017 8:34 am
Post new topic  Reply to topic  [ 14 posts ]
PostPosted: Tue May 12, 2009 10:39 pm
Any one have experience removing the logos on the red cranks?
I tried acetone............ nothing, looks like I will have to wet sand it.
TIME RXR
 Post subject:
PostPosted: Tue May 12, 2009 10:45 pm
logos under clear...
charles@pezcyclingnews.com
 Post subject:
 Post subject:
PostPosted: Tue May 12, 2009 11:00 pm
If your brave you can sand the arm down with 500 grit, and then follow with 1000 grit to smooth it out. Once your done, spray it with a urethane (minwax sealer works good, you can buy it at home depot) and you should be good to go.
11' Flash Ultimate, 1x10 - 15.7
11' SuperX Single Speed - 13.0
12' SuperX Geared - 15.3
12' Scalpel Ultimate, Wireless SRM - 18.3
 Post subject:
PostPosted: Wed May 13, 2009 4:34 am
What Minwax product?
http://www.minwax.com/
 Post subject:
PostPosted: Wed May 13, 2009 5:23 am
Are they really grinding your gears that much?
(pun intended :P )
VeloKicks
The Gram
The Men of Steel
 Post subject:
PostPosted: Wed May 13, 2009 6:32 am
a very good idea. match the newly black crankset with some stronglight chainrings for a much less industrial look.
17 and stupid, bear with me
 Post subject:
PostPosted: Wed May 13, 2009 7:18 am
Would look good IMO - please post pictures if you do it.
 Post subject:
PostPosted: Wed May 13, 2009 6:53 pm
I run campy record, but not the cranks. I have the stronglight chain rings already to go, I just need to get rid of the logos. I will let you know how the sanding goes and will post pics later. I would like a matte finish I think.
TIME RXR
 Post subject:
PostPosted: Wed May 13, 2009 7:22 pm
wrong topic
PostPosted: Fri Nov 09, 2012 5:03 am
Anyone do this? I'm interested in removing the graphics from my Red cranks. Sounds easy in theory.
edit; never mind, this thread has the details I'm looking for:
viewtopic.php?f=3&t=83500&start=45
PostPosted: Fri Nov 09, 2012 5:10 am
very easy, dremel and sand paper.
tons of clear coat :beerchug: ... 479gr on mine w/o chainring after sanding.
:beerchug:
PostPosted: Fri Nov 09, 2012 6:41 am
I removed the logos from my RED cranks by wet-sanding. I preferred the matte finish so I just used a wax. I also removed the logos from the Edge seatpost and stem.
PostPosted: Fri Nov 09, 2012 7:27 am
How thick is the clearcoat? I would assume pretty thin. Let us know how it goes.
PostPosted: Fri Nov 09, 2012 11:50 am
It did not take that long to do. I think I started wet sanding with 400 grit sand paper and finished with extra fine steel wool.
There is a razor blade technique that sounds like it may save lots of time as well.
Edit...
I did not put a clear coat on it. I did put some car wax on it for the first few months but that was about it. This is on my bad weather bike. So it gets the brunt of the winter riding with lots of road salt.
I don't think the wax or any clear coat is necessary. It still looks the same.
TIME RXR
There are no new unread posts for this topic. How to remove logos on Hylix carbon seatpost
stripes
Sat Mar 04, 2017 3:14 pm
evan326 View the latest post
There are no new unread posts for this topic. Any easy way to remove white logos on carbon rims?
Shrike
Sat Jan 28, 2017 12:11 am
Broady View the latest post
There are no new unread posts for this topic. Attachment(s) How to remove second bolt on Sram (Red) Chaingrings
jbattermann
Tue Aug 01, 2017 10:43 pm
jbattermann View the latest post
There are no new unread posts for this topic. Attachment(s) Sram Red BB30 cranks & BB30A
meanmachine
7
2288
Mon Apr 03, 2017 5:08 pm
Valbrona View the latest post
There are no new unread posts for this topic. needing help Quarq cranks Sram and rotor, swapping them between bikes.
charlie0
Sat Sep 30, 2017 12:12 am
alcatraz View the latest post
Users browsing this forum: 4371, Bing [Bot], colnagoaddict, superdx, TobinHatesYou and 35 guests
