It is currently Wed Nov 22, 2017 11:43 pm
Post new topic  Reply to topic  [ 61 posts ]  Go to page Previous 1 2 3 4 5 Next
PostPosted: Wed Sep 23, 2009 1:46 pm
with how much school work I've had. I only had 1.5 rides on it. Half a ride on sunday because it started pouring 15 miles in, which just so happened to be 2 miles from home. If it wasn't below 60° i would've continued. I'm still adjusting the fit a tad while I wait for Kevin Wilson to come down and do it properly. Should have a ride report after tonight's ride.
I am having strange front derailleur adjustment issues. Especially in the big ring. It's either the Parlee clamp holding the derailleur out too far or the right crank arm is too close to the frame. I cannot even get to the last index point otherwise the chain will be on my foot.
My Lynskey R420 with Chorus 11
If you are interested in a Weight Weenies kit I no longer know what you should do.
PostPosted: Thu Sep 24, 2009 2:44 am
So I'd give a better ride report but when there are thousands of aphids hitting your face it's hard to concentrate on the actual ride.
I feel pretty dang comfortable on it. I'm doing a century on Saturday if weather permits so we'll see how I feel after that, and can do a better ride report after that. I'm still getting used to the shifting coming from shimano but it feels a ton better. Like I mentioned earlier, I am having strange Front derailleur issues but I'll play with it some more and see what I can do.
The acceleration is unreal compared to my 22lbs steel bike. I did not think i'd notice it that much but losing a ton of rotational weight definitely shows. I'm taking it easy until KMC comes out with it's 11 speed chain. I put the chain on with a regular chain tool, it's possible but requires an extreme amount of patience and I'd much rather deal with something else. I did put some sprints in today and it held up, so I'm not worried about it breaking apart. Felt great in the sprint. I need a couple more to really get a feel for it.
The only thing I might want to change on it is get something like a -17° stem and have it a bit shorter to get some more drop. The Zipp Contour SL bars are most comfortable. The wide, flat tops make for a very comfortable forearm resting spot.
PostPosted: Thu Oct 01, 2009 9:44 pm
My latest acquisition. I need something better than a fish scale to weigh my entire bike. Weight is 14.85lbs and should go down even more when My Soul S2.0SL wheels come in. Should be a good margin under the limit with those wheels. I'll find out how comfortable this saddle is either tomorrow morning or saturday.
No pictures of the complete bike as the weather is pretty crummy. Those will probably wait until I get the soul wheels.
So far bike runs nice, drivetrain is a bit louder than I like but I've read that changing the chain not long after you purchased a new cassette will quite it down. So I'm looking forward to the KMC X11SL chain by the end of the year.
PostPosted: Mon Feb 08, 2010 3:25 pm
Beautiful build. These Lynskey Ti frames are getting more gorgeous every year.
Range || range.wordpress.com
Asterisk*Cycles
'10 Velocite Millennium Elite SRAM Red
'11 Velocite Geos w SRAM Red || '08 Giant Anthem X0 w SRAM X0 || '93 Pinarello w Shimano 105
PostPosted: Tue Feb 09, 2010 7:09 pm
Thanks, I am loving the look of the frame. Earlier this morning I took some pictures of it because this damned weather is forcing me inside. I realized that I haven't done a shot of the current setup in a while. I was about to post it in the Post your bikes here thread but Frankie got to it first.
I had a slight problem with my zipp bars hence the temp ritchey bars. Should hopefully have those bars back soon..These HED wheels are heavy, 1841g with tape. I also have a set of Campagnolo Zonda's that at the moment are reserved for roller use.
As pictured the bike weighs 7.48kg. Will lose some once my zipp bars get back, and then later this year I'll buy a nice light wheelset and begin work on getting this thing down to 6.
Oh did i mention that i hate snow? Well if it snows on Christmas Eve and Christmas day i do not mind, any other time of the year I'm no fan.
PostPosted: Tue Feb 09, 2010 9:48 pm
Those wheels make any bike look so damn fly!
PostPosted: Wed Feb 10, 2010 12:55 am
Szczuldo that's an excellent shot there mate! The frost on the ti is really cool.
Got a bigger res? Would look great as my desktop pic!
And those wheels suit it incredibly well!
VeloKicks
The Gram
The Men of Steel
PostPosted: Wed Feb 10, 2010 11:38 am
Administrator
Crank arm should be parallel to the seat tube for the perfect picture although you got the wheels right. :smartass:
RESIDENT GRUMPY OLD MAN.
PostPosted: Thu Feb 11, 2010 12:11 am
well it was cold and snowy. I made the mistake of going outside with sandals then quickly found out the snow was 6 inches deep back there.
Personally, I'd rather the valve stems be hidden by the fork and seat stays, but the snow was messing with my head. On the crank note, everyone knows that parallel to the downtube makes for a more pleasing picture. Otherwise the line from the downtube splits up too many ways and you'll lose yourself in the confusion that is caused!
PostPosted: Thu Apr 08, 2010 11:46 pm
So I feel stuck. I can't decide what more I can do to shed weight off this thing.
My ideas so far are bolt kits for derailleurs and stem, the btp carbon shifter clamps and chop excess off the seat post. An obvious choice would be to get a Vumaquad, but I don't have that kind of money..at the moment at least. My goal is to be under 15lbs with these wheels. I can get the btp bottle cages, basically 40g right there, but these just work so well.
PostPosted: Thu Apr 08, 2010 11:54 pm
I think it is perfect the way it is. But if you must shed weight, try a new frame.
Speedvagen Road
Stoemper SSCX disc
Ira Ryan XCR DI2
Parlee TT
Moots Mooto-X RSL SS
Richard Sachs Cyclocross
Scott Spark 29er
PostPosted: Fri Apr 09, 2010 12:07 am
well then it'll basically be a whole new bike so it won't be the same as shedding weight from this one.
PostPosted: Fri Apr 09, 2010 1:56 am
I know you said you want to keep the wheels, but I'd get in on that cheap carbon wheel group buy.
Gramz
Failed Custom Bike
PostPosted: Fri Apr 09, 2010 2:44 am
oh i'm in on that, don't you worry. But these are the wheels I ride most days. I have a set of Campagnolo Zonda's which are in the 1300g range but they just don't feel as nice. Mostly due to the Gatorskins that are on there compared to the vittorias on the heds.
PostPosted: Fri Apr 09, 2010 4:18 am
That's a whole lotta wheel to be riding everyday. Carbon clinchers are a rolling contradiction. You can build alloy 32h tubs (velocity escape or ambrosio corsa rims) down to low 1400g. Including the weight saved on tyres vs. clinchers (~150g) you could save around 500-600g vs. the HEDs, and end up infront in dollar terms.
They look like very deep wheels to be riding for road racing. If you are TTing, get a TT bike. If you are financially constrained, why race on carbon wheels? If you want light, why have clinchers?
If it were me, I would:
1. Sell wheels
2. Get alloy clinchers for training (1700-1800g build or stick some 25 or 27c tyres on the zondas, or get Neutrons if you care about weight for training)
3. Build (or buy complete) 1400g-ish tubbies for race day. (Say, record hubs to ambrosio corsa or velocity escape rims. Comp spokes rear, revolution front, or aerolite/CX-ray if you want to spend a little more)
IMO unless you are a tough-as-hell breakaway rider at a pretty high level of racing, aero benefits of deep section wheels are pretty minimal. Most riders spend 90% of the time sucking wheels in a pack. Most riders ride more crits than anything, in which case light beats aero even more.
There are no new unread posts for this topic. Lynskey Sportive
polaris
Sun Jul 23, 2017 4:50 am
mbaulfinger View the latest post
There are no new unread posts for this topic. 2014 lynskey helix M
WhyZ
Fri Feb 17, 2017 1:58 pm
WhyZ View the latest post
There are no new unread posts for this topic. Lynskey R350 Frameset
Imaking20
Tue Oct 31, 2017 5:20 pm
Imaking20 View the latest post
There are no new unread posts for this topic. Lynskey charges $195 to prep the frame for SRAM eTap
WonderSausage
Sun Feb 05, 2017 8:10 pm
mpulsiv View the latest post
Users browsing this forum: Google Adsense [Bot], Ulver and 21 guests
