It is currently Tue Aug 22, 2017 6:04 pm
Post new topic  Reply to topic  [ 14 posts ]
Who is the champion post?
KCNC Ti Pro Lite 71%  71%  [ 17 ]
Woodman Post EL 29%  29%  [ 7 ]
Total votes: 24
PostPosted: Wed Feb 18, 2009 4:31 pm
I'm thinking hard about which one to buy. I've come up with some pros and cons. These are completely subjective, what is a con for me might not be an issue for others. I'm strong and around 190 pounds right now.
Woodman pros: Lighter than KCNC. Shaft appears to be stronger as well with internal butting and a multi-diameter design like Extralite. Bolts are apparently beefier.
Woodman cons: Lower clamp round is made of carbon, possible durability issues?
KCNC pros: Lower clamp round is aluminum, and I've never heard of this specific part failing on the post.
KCNC cons: Slightly heavier. Supposedly weaker shaft. Supposedly bolts aren't as beefy.
Unknowns: Weight limits. KCNC publishes one. Woodman does not, at least not one that I found. If Woodman has one, this aspect is a draw. If it does not, then this is another point in their favor.
From a financial standpoint, both posts are basically identical in price. Here are links to the post's product pages.
http://kcnc-usa.com/content/view/14/29/
http://www.woodmancomponents.com/catalo ... n&art=sea3
 Post subject:
PostPosted: Wed Feb 18, 2009 5:21 pm
Administrator
No experience with the post but I do like the products that Woodman makes. I've been using their Deatgrip ti seatpost clamp and not only is it light but its not too fragile compared to some of the sub 10 gram clamps.
RESIDENT GRUMPY OLD MAN.
 Post subject:
 Post subject:
PostPosted: Wed Feb 18, 2009 5:38 pm
I'm running a woodman carbo el and I've been very happy with it. It came in exactly at claimed weight of 125g(27.2X400). I trimmed it down to the right length and it took 18g off. Scary light and no issues thus far. 165lbs.
 Post subject:
PostPosted: Wed Feb 18, 2009 6:45 pm
I would do KCNC...
I just like how pretty much everything they make performs.
charles@pezcyclingnews.com
 Post subject:
PostPosted: Wed Feb 18, 2009 6:54 pm
I just don't trust posts of that design. I've seen a few broken ones posted before... but are they in fact stronger than they look?
Vertebrae. Precision braking and shifting.
 Post subject:
PostPosted: Wed Feb 18, 2009 7:02 pm
So here's my take on these. This POV is coming from a guy thats 140-145 lbs.
The KCNC post is more like the Woodman SL than the EL. The SL has an alloy rocker, like the KCNC, while the EL has a carbon rocker. The Woodman guys do not explictly say that there is a weight limit however, I'd say if you a big guy I put you on the SL or KCNC just incase. The carbon rocker will break if you get all German on it with the torque when installing the saddle. So if you a ham-fisted heavy dumbass I'd say you may want the SL.
The actual body of posts in the same, the only diffrence is ti bolts and the rocker.
That being said, I've had no issues with mine at all, but again I'm not that heavy.
Starnut
"Don't pedal harder, pedal faster!"
Q-FACTOR IS A RED HERRING
BB30.COM
 Post subject:
PostPosted: Wed Feb 18, 2009 9:11 pm
I don't need setback on my frame, so have tried quite a few of the super-light no-setback posts.
I've used both mentioned here...the KCNC way more extensively than the Woodman. Before the KCNC I used the ORIGINAL bad-ass no-setback alu seatpost of the gods (to which these are very similar): the new ultimate. The NU weighed 92g. In my first race with it, way back when, one of the Ti bolts broke. I replaced it, and everything was fine for 10,000s of miles afterwards 'till I regrettably sold the post.
The Ti pro lite. No problems for a long while. I never really checked tightness of the bolts, or used a torque wrench, and it held up fine. Then after lapping the field in a crit one day, the rocker piece broke right as I rounded the final corner to put in the sprint.
Then got another, newer version of the pro lite. Not sure what was newer. Looked/weighed/felt the same. No problems with this one, ever. It was 300mm, and I only needed 250, but that's all. Raced it all last season, no problems. Including 15 days of superweek thrashing.
Got the woodman a few months ago because I was intrigued with the carbon rocker. Love the look of otherwise-unnoticeable subtleties like that. Also, figured it would be a better match for a carbon railed saddle, less pinch maybe? Anyhow, after one good ride, I noticed the saddle had slammed itself all the way back on the adjustment. Then I re did the adjustment, making sure the torque on both bolts was even, and have not had problems since. The post was a bit lighter than the pro lite as well. 100 vs 120? Something like that. My bike was since run over by a car, and the post might be salvageable still (though the saddle is badly scuffed).
Woodman: my vote.
I weight 165 -/+ 5lbs.
oh...one more note. The outer diameter of the woodman is larger than the pro lite. Very slightly, so the woodman is a bit harder to get in...but...much much less likely to slip. I had slippage issues with the kcnc, and had to use a beefier seatpost clamp.
The Chronic
 Post subject:
PostPosted: Sat Feb 21, 2009 4:19 pm
Well, I made a decision... The posted replies expressing a preference were 3 to 1 for the Woodman, however the poll showed 11 to 3 in favor of the KCNC. This was much better than just flipping a coin!
I went with the KCNC. Received it yesterday. 140g even in a 27.2 x 350, which is 2g under advertised weight. I couldn't be happier.
na-na-na-na-na-na-na-na-na...
PostPosted: Thu Aug 27, 2009 1:00 am
Where did you guys buy your Woodman posts?
Turn down the suck knob.
PostPosted: Thu Aug 27, 2009 4:49 am
Since there are comments about both posts failing in the past, I'd go with the one with the best warranty.
You mentioned the KCNC had a weaker shaft. Has anyone broken one of these or is it just speculation? The thought of breaking the shaft is... scary :oops:
PostPosted: Thu Aug 27, 2009 9:34 am
Administrator
Try Universalcycles.
PostPosted: Thu Aug 27, 2009 11:06 am
I managed to break the rear bolt on a KCNC hankfully about 20m from home on a long ride (I'm 85kgs). Torqued to spec.
The post is alarmingly flexible and does not inspire confidence like the Thomson Masterpiece that replaced it. For only a 20g penalty IMO its a no brainer.
The KCNC is a product that sacrificies solid performance for weight under a 85kgs plus guy.
PostPosted: Thu Aug 27, 2009 9:39 pm
Newer kcnc posts uses beefier Ti bolts (Now M6) so no more broken bolts....
If you are still not sure about ti bolts you can replace them with steel bolts with less than 10g weight gain. It will be still 20g lighter than thomson masterpiece.
PostPosted: Fri Aug 28, 2009 2:24 am
Thanks. It looks like they're out of the Woodman Post SL Plus Seatpost but I'll give them a call to order one.
That said, has anyone broken a WOODMAN post? I'm 180 lbs, so I'm not exactly light . . .
There are no new unread posts for this topic. WOODman Carbon EL seatpost
sib
7
909
Mon Oct 10, 2016 3:32 am
NiFTY View the latest post
There are no new unread posts for this topic. Carbon seat + post : Remove bracket/rails and attach seat directly to post - bonding?
alcatraz
Sun Oct 23, 2016 4:07 am
KarlC View the latest post
There are no new unread posts for this topic. Which is better. Kcnc CB4 or CB9?
Superlite
7
848
Tue Sep 27, 2016 11:41 pm
Superlite View the latest post
There are no new unread posts for this topic. Which rim—Boyd Altamont Lite, Easton R90 SL, or HED Belgium Plus?!
SeventhObsidian
Thu Sep 29, 2016 12:03 pm
coachboyd View the latest post
There are no new unread posts for this topic. KCNC Ti skewer setup question
stockae92
Sun Sep 11, 2016 5:04 am
eric01 View the latest post
Users browsing this forum: Bigger Gear, bremerradkurier, jimmerjohn123, m9olo, ODC, saverin, snowdevlin, Yahoo [Bot] and 39 guests
