It is currently Sun Dec 17, 2017 9:27 am
Post new topic  Reply to topic  [ 47 posts ]  Go to page 1 2 3 4 Next
PostPosted: Tue Aug 12, 2008 7:48 pm
I just purchased a Rize 2 as a lightweight trailbike frame, and it comes stock with a 68mm BB and XT cranks. I was considering removing the adapters and going BB30 (which is OK on the Rize, as it has an alloy BB shell, not carbon). Anyone weighed the Hollowgram SL cranks in 3x9 (probably 22/32/44) with the spindle? I am trying to figure out how much weight I can shed over the XTR cranks (797g on my scale with everything).
 Post subject:
PostPosted: Tue Aug 12, 2008 8:46 pm
with everything.. (bolts, spacers, bearings, spindle etc) - probably around 600-625g or so depending on rings. My 2x9 with FRM 42t and all bolts is 575.
11' Flash Ultimate, 1x10 - 15.7
11' SuperX Single Speed - 13.0
12' SuperX Geared - 15.3
12' Scalpel Ultimate, Wireless SRM - 18.3
 Post subject:
 Post subject:
PostPosted: Tue Aug 12, 2008 10:38 pm
My LBS has a Rize Carbon 1 in the shop. Looks so sweet with a flat bar. If only my country would justify such a bike... The bike is pretty light, considering the travel it gives.
Please post pics when your build is ready!
2011 Cannondale Flash 29er (in order)
2008 Cannondale SuperSix
2007 Cannondale Taurine (for sale)
 Post subject:
PostPosted: Tue Aug 12, 2008 10:43 pm
Cannondale Hollowgram SI SL Double (2008): 614 grams...
Cannondale Hollowgram SI Triple (2007): 726 grams...
Some pictures on the scale:
http://www.light-bikes.it/index.php?opt ... 2&catid=36
 Post subject:
PostPosted: Wed Aug 13, 2008 9:22 am
removing adapter : avoid warranty ...
but i will do the same ...my SL was 610 with stock chainrings 44-29
http://eliflap.it/
 Post subject:
PostPosted: Sat Sep 20, 2008 9:55 pm
Can i add granny to a double Hollowgram SI SL ????
Im searching the net for a 3x9 but i only found 2x9....
 Post subject:
PostPosted: Sat Sep 20, 2008 10:10 pm
I think the double ones are labelled double for a reason - IE there 2x9 only.
 Post subject:
PostPosted: Sat Sep 20, 2008 10:18 pm
thiago ...... :roll:
you can change the spider for add the granny ring
and transform a 2 x9 in a 3 x9
brazil ..... brazil..... :D :D :D
http://eliflap.it/
 Post subject:
PostPosted: Sun Sep 21, 2008 1:22 am
What up Eliflap :D
I have dicided to go with a Scalpel :D
And the light wieght of the Hollowgram SI SL is definaly going to be there..
But our trails we really need a granny thats why im hopping to get the crank with 3x9...
 Post subject:
PostPosted: Sun Sep 21, 2008 1:29 am
One more thing :D
When using a 2x9 (44-29), going up hill, the lightest, what would be the closest to when using a 3x9 (44-32-22).
 Post subject:
PostPosted: Sun Sep 21, 2008 3:44 pm
29-34 is similar to 22-26.
so riding 1-1 with double, feels like 1-3 with triple.
 Post subject:
PostPosted: Sun Sep 21, 2008 4:29 pm
1-3 on a tripple isnt that bad... Maybe ill give it a try on a double :D
About weight savings can you guys tell me the difference of a double and a tripple?!
 Post subject:
PostPosted: Sun Sep 28, 2008 3:21 pm
i have my SL 2008 completely disassebled
tomorrow i will do some pictures on scale
http://eliflap.it/
 Post subject:
PostPosted: Sun Sep 28, 2008 7:13 pm
But is it working well to remove the adapter? Thinking of doing this on my SystemSIX that I don't have any warranty on.
/jonas l
 Post subject:
PostPosted: Mon Sep 29, 2008 12:21 pm
here are pictures as promised
132mm spindle
cups and shims
http://eliflap.it/
 Post subject:
There are no new unread posts for this topic. Cannondale Hollowgram in BB386
wheelzqc
Thu Aug 03, 2017 4:30 am
wheelzqc View the latest post
There are no new unread posts for this topic. [SOLD ]Cannondale Hollowgram SL SRM
muffinman
Fri Nov 03, 2017 2:10 am
muffinman View the latest post
There are no new unread posts for this topic. Worth upgrading to cannondale hollowgram si ?
jobvisser
Thu Feb 16, 2017 10:44 pm
evan326 View the latest post
There are no new unread posts for this topic. Cannondale Hollowgram SiSL2 - 175 mm, 3 x 10-arm spiderings
locktopus
Thu Nov 23, 2017 3:05 pm
locktopus View the latest post
There are no new unread posts for this topic. Attachment(s) Cannondale Hollowgram SI CrankSet 52/36T 170mm new
si1ver
Wed Nov 01, 2017 6:39 am
si1ver View the latest post
Users browsing this forum: No registered users and 5 guests
